Too much hp-talk, let's talk real life numbers!
#196
Originally Posted by MarkRobinson
I was hoping you water-cooled turbo-junkies might be more interested in my turbo'd 928, but oh well, I'll stay bastardized in my own corner.
#198
Geez, just line them up.
You have a few in this thread that aren't afraid to seek each other out for a mutual circle jerk of technical masturbation.
Feel free to hang around. It's just about to get fun again.
#200
Monkeys Removed by Request
For the record my 14.0 1/4 mile run was when my 951 was bone freggin stock down to the paper filter.
Some people just like talking **** what can I say.
the car as it sits right now is prolly a mid 12 with the same or better 60ft.
#201
Originally Posted by special tool
Thomas - excellent!!
I am so glad to have you back in your old mode of making insane posts!!
Welcome back, friend.
Feel free to prove me wrong in any way.
#203
Yes - certainly I should bear the burden of proof???
I am not the one discrediting a calibrated instrument.
You and I go around and around on this, Thomas.
It is my opinion that the lack of sunlight has affected your judgement regarding testing equipment.
#204
Special,
what psi boost was your big dyno run. (I believe it was 24 psi)
Power = torque x RPM divided by a constant
Stock 951S has 247 bhp (if you can believe Porsche)
The only way you are increasing to 600 bhp from a stock 951S is through higher specific torque because your displacement and RPM (according to your dyno) are the same as the stock 951S.
It should be painfully obvious to you that your number is impossible to achieve unless your volumetric efficiency and thermal efficiency are astronomical, the likes of which are beyond comprehension to internal combustion engine physics.
"calibrated intrument" is just propaganda. It means nothing to me if I see "to good to be true" numbers.
Let common sense be your guide.
#205
I work in a company were calibrated testing equipment is everything. Every single measurement instrument that in some way effects the production is calibrated at regular intervals so I think I have a pretty good idea on how measurement instruments should be handled.
What I don't understand is how dyno numbers can be regarded as accurate at the same time as people here seem to agree that DynoJet numbers are 10-15% higher than Mustang numbers. And of course DynoJet is the more accurate of them...
I do think dyno numbers can be useful when evaluating changes to one car but then they have to come from the same dyno and preferably be made at the same day and by the same operator.
And in the end I still stand by my opinion that doesn't seem so popular here.
It's not what a car has that's important, it's what it does!
#206
I think more people go to the dyno to get the AFR correct . The number is not important from dyno to dyno unless you just want to beat your chest about it.An if you need to do that just go race because in the end its about whos in front not who has 400 whp and who has 500whp. My 2 cents
#208
Tool: If you only knew how much daylight we have in summer... ...even here "down south" we have 20-21 hours a day in July.
TurboTommy: Tool runs on "homebrew"...serious mix of aromatics and gas. He has a seriously increased VE and thermal efficiency,some of it I guess is a result of the burn speed of that juice,and the possible ignition settings he can run on that without knock. I find that "max hp bump" in the dyno peculiar,not to say unusual,but that can be any sort of tuning effects co-working at that rpm. Or not.
#209
If I just purchased a new Z06 from a dealer that claims 505 hp. I should call BS and ask him for a 60-100mph time slip instead. I would have to tell him that a dyno doesn't exist that can accurately measure the real hp that GM claims.
I can honestly see how this 60-100 test is beneficial to someone that doesn't have a dyno close to where they live. Or can safely and legally do it on an open road. If this is the only testing method they have. Than use it. Don't try to lure others that don't have the ability to do the same test. Than portray yourself as having a faster car because nobody is up for your challenge. I believe that there are many dynos in europe. I suggest you try and find one if you would like to compare with us americans that can't do your type of testing.
Even in america. The only people that claim dynos are inaccurate are the ones that don't like there results.
#210
Originally Posted by ehall
Big John, pass me another beer. This is getting fun.
cripes!...got some popcorn in my teeth...TIME OUT!
