Rolex Partners Up With Vitesse Racing & Special Tool
Old 10-05-2005, 04:03 AM
  #136
NZ951
NZ951's Avatar
Originally Posted by Skunk Workz
30 psi on pump..?
Hmmm I wonder if that includes water injection to supress detonation.
Old 10-05-2005, 04:12 AM
  #137
Skunk Workz
Skunk Workz's Avatar
I can't tell what he will do...but WI isn't needed if it's done the proper way. We've run 30 psi on pump on basically every tuned (non-Porsche that is) car up here for atleast 8-9 years...and it's no harder to do that with the 951s. Markus have proved that...too bad he beat me to it.
All that's needed is to get rid of 2 major shortcomings seen in most of the setups...but I see it used over and over again... Which is nice,it makes my job so much easier.
Old 10-05-2005, 04:15 AM
  #138
NZ951
NZ951's Avatar
I think I know what you are talking about
Old 10-05-2005, 04:58 AM
  #139
IanS
IanS's Avatar
Ah standalone. I've been hoping to avoid that, but it certainly solves the ignition issue. And $40 is a very reasonable price.
How are they working compared to the stock distributor setup? Are you running bigger plug gaps?
-Ian
Ian,
Its just a set of used EVO coils ($40), I made the bracket, and a set of Magnacor wires... I have a Link standalone and it uses a duel channel igniter obviously. When I go coil on plug I will need one of the Performance Developments sync cam.
Old 10-05-2005, 09:35 AM
  #140
Weissach Vampire
Weissach Vampire's Avatar
IAll that's needed is to get rid of 2 major shortcomings seen in most of the setups...but I see it used over and over again...
And those shortcomings are __________ (please fill in the blank space)
Old 10-05-2005, 09:52 AM
  #141
RolexNJ
RolexNJ's Avatar
Joe: So you have a plan to run 30PSI? Wow. I hope you have all the proper hardward in place, let alone an "expert" tuner. Can you let us in more on the details?
Old 10-05-2005, 10:12 AM
  #142
Markus951
Markus951's Avatar
I saw that my name have been mentioned here. Anyway, i've try'd 30 psi but my injectors are on 100% duty @ 6500 rpm (680cc). I have only 3 bar map sensor so it can get tricky. But if I raise fuel pressure to 6 bar at idle then my injectors should be something like 950cc-s so that should be enought to run even 37 psi. Of course I need to change that stock head gasket first. But since I need to sort out cam probem first (I have surge on full load on 4 th gear) no point really to raise boost. But i will try 40 psi in spring with new cam, new map sensor, new headgasket and more proper tuning.
Daily I drive 26 psi, plenty for me
Old 10-05-2005, 10:13 AM
  #143
special tool
special tool's Avatar
Markus - what is the part number of your fuel pump?
Old 10-05-2005, 10:27 AM
  #144
testarossa_td
testarossa_td's Avatar
Quick OT. What is the color code for your car...that is sweeeet!
Old 10-05-2005, 10:33 AM
  #145
OriginalSterm
OriginalSterm's Avatar
But if I raise fuel pressure to 6 bar at idle...
6 bar!!! wow that's a lot of pressure!
Old 10-05-2005, 11:55 AM
  #146
Skunk Workz
The space isn't long enough... ...But,seriously,if you'd found the Holy Grail,would you tell all about it..? I'm trying to make a living out of this...and besides,nobody here listens to me anyway,so I'll just kick out some teasers now and then until the project car is done... But then nobody will belive the dyno,I guess...
Old 10-05-2005, 11:57 AM
  #147
special tool
I will believe the dyno.
But I may still make fun of you personally.
Old 10-05-2005, 12:10 PM
  #148
Skunk Workz
Perfectly ok. Just let me know when you get a '42 to spool below 3500 rpm without antilag,so we are in the same league...
Old 10-05-2005, 12:20 PM
  #149
TRWright
TRWright's Avatar
Them is fightin' werds!!!!!!
Old 10-05-2005, 12:27 PM
  #150
special tool
Talk is cheap.
Skunk - you'll make someone a great wife someday, with all the talking you do.
Quick Reply: Rolex Partners Up With Vitesse Racing & Special Tool
