Engine Analyzer... library of parts and values
Below are specifications to use on the Engine Analyzer. Given I have not verified the specs of the mods personally, I cant assure they are precise, but I have them from a source that seems credible.
Shortblock specs
Bore: 100
Stroke: 78.9
# of Cylinders:4
Piston rings: 3 Standard tension
Rod lenght: 150
Piston Skirt: Typical
Bearing Size: 1.26 Calc
Piston Top: No coating
Cyl Leakage:Low Leakage
Cooling Fan type: Electric
Water pump & drive: Production Size
Engine+ Dyno Inertia: Eng only,Std Flywheel
Design: Typical Windage
Head (measure in inch)
LINDSEY RACING STAGE 3 Porting with 47,8mm intake valves
Intake
Valve diameter 47.8
Average port diameter 42.13
Port length 82.5
Full Intake Flow table @ 28"
Valve Lift"......mm......Flow,CFM
0,07874..........2..........49,57
0,15748..........4..........91,76
0,23622..........6........133,526
0,31496..........8........168,1
0,3937..........10........201,696
0,47244........12........226,357
0,55118........14........239,894
0,62992........16........248,26
Anti-reversion % 0
Compression ratio 8
Exhaust
Valve diameter 38 (Lindsey's HighVelocity Option...)
Average port diameter 34.16
Port length 107.5
Single flow coef .597
Anti-reversion % 0
Chamber design Typical Wedge
LINDSEY RACING STAGE 2 Porting with 45 mm intake valves
Intake
Valve diameter 45
Average port diameter 42.02
Port length 82.5
Anti-reversion % 0
0,07874..........2..........51.109
0,15748..........4........102.65
0,23622..........6........147.469
0,31496..........8........174.329
0,3937..........10........194.797
0,47244........12........211.058
0,55118........14........222.474
0,59055........15........226.759
Exhaust
Valve diameter 40
Port length 107.5
Anti-reversion % 0
CR 8:1............................................Material/coating: Aluminium
Chamber design:Typical Wedge.................Burn Rating:Typical
STOCK 951 HEAD
Intake port specs:........................... Exhaust port Specs
# valves/Ports: 1valve &1 port .................1 valve& 1 port
Intake valve dia: 45....................................... 40
Avg port Dia: 41.39 .......................................34.16
Port lenght: 82.5 ..........................................107.5
Anti-rev: 0%................................................. 0%
Intake flow table @ 28" Ex. Single Flow Coeff: 0.597
Valve lift ". ..........mm.....................Flow CFM
0.0787..................2........................ 47,047
0,1575 .................4.........................95,524
0,2362 .................6.......................146,386
0,31496 ...............8.......................168,395
0,3937 ...............10.......................178,596
0,4724 ...............12.......................194,373
0,53149..............14....................... 201.73
CR: 8:1 .....................................Material/ Coating: Aluminium
Chamber design: Typical Wedge......... Burn rating: Typical
Intake
STOCK 951 INTAKE:
Runner Dia @ head: 41.5 Throttle Body CFM rating: 376 (from flow #)
Design: Tapered runners
Runner length:327
Runner Flow Coeff: 3 Air Cleaner CFM: 326 (from stock AF dimensions)
Runner taper: 2.24
Manifold Type: Single plenum-EFI
Intake Heat: No heat.
Exhaust
Cam
Webcam #274
Intake Profile
Centerline. deg ATDC 106
Duration @ .050" 234
Open @ .050 ", BTDC 11
Close @ .050", ABDC 43
Max Lobe Lift .484
Gross valve lift .484
Duration @ .200" 163.6
Exhaust Profile
Centerline. deg ATDC 110
Open @ .050 ", BTDC 47
Close @ .050", ABDC 7
Max Lobe Lift .484
Lobe separation 108
Turbo
LINDSEY RACING Stage 5 "Club" turbo (Turbonetics 60-1)
Island CFM 544.67
Island pressure ratio 1.725
Island efficiency % 78
Surge CFM 320.66
Turbine nozzle diameter 1.26
Intercooler
intercooler CFM 167
Shortblock specs
Bore: 100
Stroke: 78.9
# of Cylinders:4
Rod lenght: 150
Intake
Valve diameter 47.8
Port length 82.5
Anti-reversion % 0
Compression ratio 8
Exhaust
Port length 107.5
Anti-reversion % 0
Intake
Valve diameter 45
Port length 82.5
Anti-reversion % 0
Exhaust
Valve diameter 40
Port length 107.5
Anti-reversion % 0
STOCK 951 HEAD
Intake
STOCK 951 INTAKE:
Runner length:327
Runner taper: 2.24
Exhaust
Cam
Webcam #274
Intake Profile
Max Lobe Lift .484
Exhaust Profile
Max Lobe Lift .484
Lobe separation 108
Turbo
Island CFM 544.67
Surge CFM 320.66
Intercooler
intercooler CFM 167
PS if anyone else has used it, can you please post every possible stock and modded Specs you can? I have a LOT of Lindsey Racing parts in a profile I found so it will be cool to make an online resource.
Stock "early" NA and all Turbo cam lift is 12/11mm (intake/exhaust)
Stock "late" NA cam lift is 12/12mm (intake/exhaust)
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/201615-944-turbo-and-high-lift-duration-cam.html
Awesome, thanks...
Anyone got the head specs like valve and port diameters?
PS so far the engine analyser with almost my exact setup, is within 5 WHP of what I dyno'ed...
Are you gonna post all the settings and such? I think I have a copy at home, id love to have an estimate of what my car will do.
How do you account for mods like head porting etc?
Depends what people want! there are hundreds of settings.
Maybe we try and create a library of the various?
You can change the port diameters...
I must have missed it... whats the "Engine Analyzer"?
Regards,
Regards,
http://www.performancetrends.com/EA30.htm
"Desktop Dyno" Helps predict what various things might do for a specified engine's output.
Originally Posted by Duke
Very impressive piece of software!
Please let the specs coming... please share all the parts file you have made so we can make a library.
I am working on my runner length for the intake, looks like I will gain 20-25HP up top and lose 5-7 down low with 8 inch runners. Nice to be able to have a clue before I make the whole thing
Head
Intake
Valve diameter 47.8
Port length 82.5
Single flow coef .532 (I have a full flow table available...)
Anti-reversion % 0
Compression ratio 8
Exhaust
Port length 107.5
Anti-reversion % 0
intercooler CFM 141...(from flow numbers)
Screwed around with this a little tonight. Used a lot of the base settings that were already in there.
Seems pretty fictional until I actually get my car together to have something to compare numbers with.
