Rennlist Top 10 HP/TQ
#1068
It's the same problem I had with the 3 liter registry post. IB has apparently eliminated the ability to edit posts after a little while. So you can't keep the list updated in the first post. Time to mull over some work around...
#1070
#1072
Maybe if you loose some rubles for membership the will let you edit?
#1074
I'm a paid member and I can't edit old posts either. Here's my idea: in the first post, if we could embed an image of a pdf or other file with the list, which is hosted offline, the embedded image could be edited offline and that way kept up to date in the first post? Probably needs a new post, unless Refresh can use his Mod powers to embed the remote image in the first link. Not entirely sure it would work, but seem like it should?
#1077
Would it help if we all sent in results rather than someone scrolling through a million posts trying to find relevant ones? If so we have a 2.5 8v w/ 518whp /445wtq @ 26psi (not even close to the Tool's) and a 3.1 8v w/ 552whp / 520wtq @25psi (different dyno's, conditions, tyres etc notwithstanding).
#1078
I wasn't the keeper of the HP list, and the 3 liter registry post has turned into more of a 3 liter discussion than list of motors (since it couldn't be updated)... So I don't have a list to send unfortunately...
#1079
Yes, please post or pm me and I will update
