Rennlist Top 10 HP/TQ
Old 03-18-2011, 07:38 PM
  #1006
piperporsche180944
piperporsche180944's Avatar
Well boys, I didnt make the list at a low 15lbs
Mods: 61-1, LR MAF, LR DP WG, 3" Exhaust, 55# Injectors, No head work.
http://www.youtube.com/watch?v=KwSZLeSubcE
The first run (Blue) was in 4th gear, the second (Red) was done in 3rd and put out less power.
Last edited by piperporsche180944; 03-18-2011 at 07:41 PM. Reason: Added to Dyno Description.
Old 03-19-2011, 01:57 AM
  #1007
333pg333
333pg333's Avatar
What were you hoping for?
Old 03-19-2011, 03:58 AM
  #1008
piperporsche180944
315ish rwhp was the goal
Old 03-19-2011, 04:39 AM
  #1009
joster86turbo
joster86turbo's Avatar
3 more pounds will get ya there
Old 03-19-2011, 12:38 PM
  #1010
piperporsche180944
Shes going back to the knife here soon. I plan on finding a stand alone ECU, 83# Injectors, ARP Head Studs, Welbro 255 Fuel Pump and crank up the boost.
Old 03-30-2011, 04:00 PM
  #1011
toddk911
Drive-by provocation guy
toddk911's Avatar
Any chance to find out what boost those on the list were running and pump or race?
Big difference between say 400hp on 20psi and 400hp on 15psi.
Same with safe 20psi on pump is more impressive than 20psi on race gas.
Old 03-30-2011, 04:12 PM
  #1012
racerxrick
racerxrick's Avatar
Noticing that you are one of the long time listers here I am curious what kind of power you lay down? I assume you have a good handle on it since you've stuck with it so long No easy feat in itself!!!
Old 03-30-2011, 04:35 PM
  #1013
toddk911
toddk911's Avatar
Yes, I have stuck with it thanks to beer and a punching bag!! LOL!!
I have only one offical dyno from a Mustang dyno and was 5+ years ago with not the current mods. That was 320whp at 18psi on pump. Tune was not very accurate and many say Mustang reads 5-10% lower than dyno jet, etc.
Based on current set up and passengers with fairly accurate butt dynos, lol, the ball park estimates are around 375whp.
Hoping to get it on the dyno in the near future.
Old 01-20-2012, 10:34 AM
  #1014
johan84
4th Gear
johan84's Avatar
Default strenght automatics and manual's
hello guy's
i have seen on the first page that there are a few 928 with serious hp/tq range
but how much can a automatic or manual handle
and are there aftermarket mods availible?
610tq is alot but can a stock gearbox handle that
gr johan
Old 01-20-2012, 12:13 PM
  #1015
Paulyy
Professional Hoon
Paulyy's Avatar
Originally Posted by johan84
hello guy's
gr johan
You're better off in the 928 forum asking those questions.
Old 01-20-2012, 04:00 PM
  #1016
Duke
Duke's Avatar
Hmm I see I still haven't been added to the list. When I have the time to put my new car together I will have to do a glory run to top the list
Old 01-20-2012, 04:21 PM
  #1017
reno808
reno808's Avatar
hopefully i'll make top 10 inn the 2.5 list
Old 01-20-2012, 04:40 PM
  #1018
NZ951
NZ951's Avatar
Sorry darling, have I missed some admin? What post do I need to refer to to get you on the list?
Old 01-21-2012, 11:40 PM
  #1019
333pg333
333pg333's Avatar
Duke's final motor in the Green Hornet
3.0l 16v turbo 968 variocam engine. 514 rwhp / 450 ft/lb @ 17 psi pump gas
Old 01-22-2012, 01:26 AM
  #1020
NZ951
NZ951's Avatar
Thank you sweetheart, I have amended the list
Quick Reply: Rennlist Top 10 HP/TQ
