Rennlist Top 10 HP/TQ
#872
You should be able to exactly calculate the brake specific fuel consumption. Its just pounds per hour of fuel flow over horsepower. Its really a measure of thermal efficiency... as you know.
#874
NZ951:
I see you added someone new to the list, and that's great for CMF! I am surprised though that you didn't add George D and his 3.0L that made 531 RWHP. I believe he should take the #2 spot now right behind Zoran. You may want to add him to that list, and remove him from the 2.5L one.
https://rennlist.com/forums/944-turb...-23-4-psi.html
#875
Corleone:
Here is mine:
104 mm
Darton MID
JE coated
2.5 951 head
Link G2
GT3582 - 1.06
JME solid cam
449 rwhp at 1 bar gas
560 rwhp at 1.25 bar E85
Here is mine:
104 mm
Darton MID
JE coated
2.5 951 head
Link G2
GT3582 - 1.06
JME solid cam
#878
3L and I don't have his dyno chart plus he's a bit hard to get a hold of. I'll see if he responds to an email Andrew.
#884
It was a heat issue in the dyno shop and the inj were maxxing out.
#885
The Greddy boost controler was acting crazy. Boost was going up and down. It only hit 23.4psi right at the rev limiter, for split second. Before that it was consistenly between 21 and 22 psi. I pulled out every trick in the book to tget that controller to make these boost levels on the dyno.On the street it was no problem.We were running lean too so that probabaly didnt help the situation.That is why we called it quits.With a bit more boost(if it could be controlled) and some more fuel,we could have easily done 550+, possible even 600WHP.
