What do you mean? The only gauge that will work with the sensor the brad is making? No any gauge that is designed for 300* SHOULD work but im not putting money on it. Check the website there are plenty of gauges that should work with it.
Yes, any 300 degree F VDO temp gauge will work. If you want some other different gauge (like autometer), wait until this is all over and I'll see what I can do :-)
Ah thanks. That is exactly what I'm looking for. Let me know!
I see:
150F - 300F / 50C - 150C 2 1/1/6" Engine Oil $33.35
Mentions that it uses the 10-180Ohm sending unit, which I presume is the one we're using, since it's the 'new' one.
