Feeler: Be Cool!
Old 05-09-2005, 06:09 PM
  #151
Bill
Bill's Avatar
Ed,
I will e-mail you tonight from home.
Sam,
Ok, I will try your method. See below.
THE PROTOTYPE HAS LANDED
Old 05-09-2005, 06:49 PM
  #152
Mike B
Done With Sidepatch
Mike B's Avatar
Nice house..nicer carton.
Is anyone involved in the group buy planning to attending Griffin and picking up their new rad? I would like to try and avoid the UPS brokerage fee otherwise known as "the shaft".
Old 05-09-2005, 08:17 PM
  #153
Jon Moeller
Jon Moeller's Avatar
I'm dying here. I can look at boxes out in my garage!
We want the radiator!
Old 05-09-2005, 08:26 PM
  #154
Crazy Eddie
Crazy Eddie's Avatar
Old 05-09-2005, 11:58 PM
  #155
Bill
Bill's Avatar
This is my failed stock radiator. 70,000 miles on the clock. You can see the rust trail from the left side tank leaking.
Old 05-10-2005, 12:06 AM
  #156
Bill
Bill's Avatar
Here it is! The all aluminum Griffin radiator next to the crappy plastic stock unit. The stock radiator weights 10lbs, while the Griffin rad weights 7lbs. A direct bolt in unit, with all the correct mounts and brackets.
Old 05-10-2005, 12:19 AM
  #157
Bill
Bill's Avatar
Aluminum end tank, beautifully heliarc welded. Aluminum fittings. No brass or other dissimilar metals that can cause a dialectric failure. If you look close to the point where the tubes meet the end tank, you will see the red epoxy reinforcing process that is unique to Griffin. The cooling tubes are welded to the end tank, then as an added measure epoxy is injected.
Old 05-10-2005, 12:29 AM
  #158
Rob 3
Rob 3's Avatar
A rose by any other name:
nice piece of fabrication!
Old 05-10-2005, 12:32 AM
  #159
Bill
Bill's Avatar
The left side of the radiator with the thermal fan switch installed. This is one of the tweaks that Griffin is going to make, moving the fan switch up 1/4" to give more clearance for the fan shroud. Note the small upper most nipple. On the stock radiator, this is the plastic one that some have broken off while working in the area. This won't happen on the Griffin rad. Above the small nipple, the U shaped bracket is where the rubber mounting grommet sits. These isolate the radiator from the electric chassis ground. Again to prevent diaelectric failure. I gave the Porsche part numbers for the rubber mounts, in a prior post. The lower grommets are a two day special order. The upper grommets come from Germany, two weeks (Hint, order now).
Old 05-10-2005, 12:42 AM
  #160
Jon Moeller
Bill,
Does this mean we can start calling Griffin?
Again, thank you very much for organizing this group buy. I can't wait to get mine into my car.
-Jon
Old 05-10-2005, 12:50 AM
  #161
Bill
Bill's Avatar
Jon,
Griffin will take your group buy orders this Wednesday 5/11. This is after the tweeks to make the next run of radiators perfect, go back to engineering.
I will post the order information around 9am PST Wednesday. Each order will be handled as a individual order. Another words, first come first served. Griffin currently has orders for a thousand (1,000) radiators. So your radiators will take around 3 weeks to pump out.
I in the mean time, will be driving with a slightly less than perfect "Prototype". Nothing a Dremel grinder could not handle. With "driving" being the key word here!
Old 05-10-2005, 12:56 AM
  #162
Bill
Bill's Avatar
Double whammy.....my water pump also failed! So off with the old and on with the new. You should be able to install the radiator without removing all this stuff though.
Yes, I have the ultra rare Guards Red edition.
Old 05-10-2005, 01:08 AM
  #163
Bill
Bill's Avatar
While the radiator is out of the car, make sure you spend some time cleaning out the fins of the A/C condensor that sits in front of the radiator. Use an air nosel and blow from the engine compartment side to eject crud from the 1" thick condensor. I spent an hour and a half picking and blowing out small stones, bird feathers and leaves. I bet this crud restricted air flow by at least 10%.
How do you like the hand model I hired for this pic?
Old 05-10-2005, 01:23 AM
  #164
Bill
Bill's Avatar
And this is what an hour and a half will get you.....about a golf ball sized pile of crud.
And not your garden variety crud mind you.....Pizza Run Crud!
Old 05-10-2005, 01:31 AM
  #165
Bill
Bill's Avatar
And last but not least....The Griffin radiator nestled in its new home, peeking back out at me. The Snap On ratchet sits on the set screw, that pinches the rubber mounting grommet to the cross member.
My 951 is happy again.
Quick Reply: Feeler: Be Cool!
