Part# for 3L crank?
Part# for 3L crank?
I just came across a 3L crank (need to measure to make sure), with a different part#.
The part # on the crank is: 944 103 7R
Can anyone shed some light on this? Cranks I have seen have a part #:
944 102 015 XX where XX is: 09, 11, 13 or 15..
Did you ever confirm this as a 3.0L crank... I have a 3.0L and 2.5L crank, and am having trouble visually telling them apart. The one I suspect as the 3.0L has this part number (944 103 7 R) on it as well.
Upper one is a 2,5 crank, lower 3,0 one
Your eyes must be better than mine... I guess if I look hard enough I can see the difference, but it's not something I would consider "obvious". I just would really like to have 100% confidence before I ship the wrong one out... and the only way I know to do that is to check the part #.
Look at the rod journals, the distance on the outside - or make a straight line on a main journal make a straight line on the rod journal and measure that distance (stroke)
