Anybody have any experience of MySwiss Venturi Delete
I am thinking of getting one of these, but can't find a price anywhere on his site.
As I am in UK the phone is a bit expensive for something this size. Does everything fit properly?
MySwiss if you are reading here how much is the kit?
Cheers
Tom
Cheers
Tom
Works great - since it's all factory hoses! It's simply the hose setup from the late 951, which is also here:
http://www.lindseyracing.com/Merchan...KEMANIFOLDMISC
I believe he (MySwiss) also throws in silicone hose for all the small vac lines, and 4 manifold gaskets, with his kit, for a likewise higher price.
Sam
Sam
Thanks guys I thought it replaced that metal pipework under the manifold. I have a 1991 car and have just got one of Lausts vacum manifolds. Deleted the cycling valve as I now have a dual port wastegate and therefore is the metal vacuum transfer pipe really needed for anything???
Tom
Tom
It does replace that metal Y-pipe under the manifold. What you end up with is a large hose from manifold to brake booster, and then the 2 ISV hoses - everything else gets gutted out of there, leaving the 3 large hoses and the small vacuum lines that do FPR, TB, gas canister, etc.
Sam
Sam
Sam
Sam
UAE Rennlist Ambassador
Sam: The metal Y is the one wher ethe CV goes? that is an X (other than that, i never noticed and metal Y's under the intake), or is that the venturi you are talking about?
Tom: Here is a thread i started showing the intake when it is off, hoses, venturi delete (LR and MySwiss comparison) and various other things Here
This is the mess of hoses that were under my intake (they broke uppon removal):
Hi Guys.The complete vacuum hose kit the we offer is 70$ plus shipping(usualy 8$ within the US)
It includes the following:
2 factory updated idle stabilizer hoses
1 blue silicone hose for the brake booster to manifold feed(we can special order the factory part for 31$ extra)
20' of blue silicone vacuum hose (5/32")
5 brass T fittings
4 intake manifold gaskets
1 blue silicone hose, to go between the MAF and crank case metal pipe
Vacuum line instructions.
We can sell these parts individually or as a kit. We only have the silicone in blue for now.
Our e-mail is sales@europartsetc.com
5 brass T fittings
Rocket Scientist
5 brass T fittings
5 brass T fittings
