Your Not Gonna Believe This SHI$$ HELP!!
#92
Drive-by provocation guy
Nope, still under the tree ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
IT'S NOT THE WASTEGATE.
I just got back from my buddies with the compressor and I put a line on it and could hear the WG open and close.
Gonna drop it off tonight at the shop and see if they can find anything. Although, a screaming turbo and no boost =..................
I also left a message for Dave Lindsey to let him know what is going on.
What could have heppend to a newly rebuilt turbo????????
#96
"If a bad TPS causing the DME to use the incorrect fuel/timing then you cannot generate enough exhaust energy to spin the turbo."
Even if I hear the turbo really spooling ???
#97
If your intake is at all clogged, the restriction will be transfered to an old softening factory j-boot - which will collapse. And yes, you will hear the turbo loud as hell
Try a boost run without the filter
#100
Darius, are you getting any of my emails..
fast951
John something is wrong with my e mail....have none of your e mails..I will look into it , thank you for your time!!
fast951
#101
When you checked the compressor wheel, was the axle turning with the wheel? Since it is a friction fit it can come loose and then it is not advisable (to say the least) to continue driving.
Bengt
Bengt
#102
Rest In Peace Jaak
Cable Guy
Cable Guy
Originally Posted by toddk911
The TPS testing with car just on? or idle? running?
#103
UAE Rennlist Ambassador
OT: Todd, you say that you have a 60-1HIFI with a #6 hotside, yet your sig says Lindsey Racing Super 61, i remember it reading 60-1HIFI a few days ago?????
#104
I was told that mine more closely resembles the Super 61 then the 60-1 hi fi, as mine is the TO4B and hifi is a TO4E.
#105
It's up at the shop now, so I just gotta wait and see what they find.
Havn't got a call back from Dave Lindsey yet.
