Your Not Gonna Believe This SHI$$ HELP!!
#76
Originally Posted by hosrom_951
Thats a lot of zeros John ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
#80
Drive-by provocation guy
Now if I can just get John to come visit Disney World !!!
Would be like having Picaso come help you on one of your paintings![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
On the turbo odds, I kinda feel all or nothing. I.e. it is just rebuilt so unless some object got sucked in, which does not seel to be, no way it could have gone bad. Although, fresh rebuild, maybe I didn't give enough "break in time"???
And then I rememeber John mentioning about the big compressor and small hotside and that causing a lot of backpressure within the turbo, that there was some compressor surge or something that affected the internals of the turbo and broke the shaft, etc.
I guess in the back of my mind it is jsut to coincidental with the new turbo. And I always expect the worst to happen. Yea, my wife hates that I always see or look for the negatives![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
To be honest guys, if it is the turbo, the car will probably go for sale. Unless Dave would cover the cost of repair and the cost to remove and instal, which I doubt would be the case.
#81
UAE Rennlist Ambassador
When i talked to the Turbonetics dealer here regarding 'breaking in a turbocharger' he said and quote" Drive it like you stole it', unless he's mistaken i never heard of breaking in a turbocharger....
ANy failures due to manufacturing assembley, workmanship etc SHOULD be covered, but this woul dtake time since you have to remove the turbo (Arg) ship it to them, they have to inspect it blah blah........
You jumping into the worse cases as you mentioned
let's just hold on and see what goes on........
Do you have a used (working) TPS or could you borrow one for testing (as Fast951 mentioned).
#82
Thanks for the postive feedback and outlook Hos. It helps!!
And to all the other guys posting help as usual, thanks!!
Well, I did the "click" test of the TPS and that was fine. How else can you test it?
#84
If a bad TPS causing the DME to use the incorrect fuel/timing then you cannot generate enough exhaust energy to spin the turbo. That's why I was asking if you hear intake pops, as indication of lean mixture under load & WOT...
#86
Quote:
Originally Posted by NZ951
How much are you charging for this John! Nice to have you around at times like these...
$0000 Just trying to help..
fast951
NZ can you believe this guy...and it's not like he has time to waste.....keep in mind I have not given John a cent of my money...all the previous owner and they are not best frinds now....
John I'll email you the data as soon as I can get my hands on a Laptop computer..thanks again![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
By the way? have you read my post/goal in the 4K hp Bob Norwood post?.I am serious...would love to have some of your products for that..see what your tinkering can do...
fast951
#87
no laptop you say?...I know..I am a bit behind......but hey just recently I bought Jackstands...I was using tree stumps/trunks..of even height of course!!
#90
Rest In Peace Jaak
Cable Guy
Cable Guy
TPS Testing
Control unit plug terminal 2 to ground:
* throtle closed 0 ohms
* throtle open infinite ohms
Control unit plug terminal 3 to ground:
* throtle closed Infinite ohms
* throtle open 0 ohms
Air Flow Sensor Check:
* terminal 3 and ground 5 volts DC
Voltage between terminal 2 and ground :
* sensor door closed 250 to 260 millivolts
* sensor door open 4.6 volts DC
Air Flow sensor temperature sensor:
Resistance between connector terminals 6 and 22:
* 1.4 to 3.6 K ohms @ 59 to 86 degrees F (15 to 30 degrees C)
Hope this helps.
Hope this helps.
