Your Not Gonna Believe This SHI$$ HELP!!
Old 01-07-2005, 09:01 PM
  #31
daniel951
daniel951's Avatar
sounds like the wastegate or line running to it is having problems. Also what kind of boost controller are u running?
Old 01-07-2005, 09:02 PM
  #32
toddk911
Drive-by provocation guy
toddk911's Avatar
OK, John, will do!!
Hey Atlanta is only a 6 hour drive to Orlando
Old 01-07-2005, 09:04 PM
  #33
Porsche-O-Phile
Porsche-O-Phile's Avatar
Sounds like it could be the TPS. . .
Old 01-07-2005, 09:10 PM
  #34
Jeremy Himsel
Jeremy Himsel's Avatar
Originally Posted by special tool
just to get away from my wife - who is currently entertaining aunt flow.
That's the first thing to make me laugh all day. Thanks. Oh yeah, been there most of the week.
  #35
toddk911
toddk911's Avatar
"sounds like the wastegate or line running to it is having problems. Also what kind of boost controller are u running?"
Ok, will do the wg exhaust test and line test tomorrow.
"Sounds like it could be the TPS"
I checked it. Was hooked up fine. I un hooked it, gave it a good look then re pluged in and stil the same.
Old 01-07-2005, 09:12 PM
  #36
toddk911
toddk911's Avatar
"That's the first thing to make me laugh all day. Thanks. Oh yeah, been there most of the week."
Honey, I'm just gonna go play in traffic for the next 4-7 days
Old 01-07-2005, 11:04 PM
  #37
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
ToddK911: First of all, 60-1HIFI's use TO4E compressors not TO4B's (unless you got yours that way).
Since you hear the turbocharger spooling LOUD and you mentioned, was is just as loud when you had boost or the same?
Everyone already mentioned testing the WG and it's probably stuck, but did you check the WG to IC banjo line (both at the IC banjo and WG)? are you running EBC or MBC?
Old 01-08-2005, 12:01 AM
  #38
Darius Juca
Darius Juca's Avatar
souds like the problem I am having...is your turbo spooling at all...does it cutout when you start hitting boost?
Old 01-08-2005, 12:06 AM
  #39
Ian Carr
That Guy
Ian Carr's Avatar
Could it be the hose off the banjo bolt going down to the wastegate cracked or some thing and now the waste gate is stuck open (loud spooling noise) and all your boost is just going out the cracked hose?
-Ian
Old 01-08-2005, 12:07 AM
  #40
fast951
fast951's Avatar
Are you using the cycling valve or an aftermarket boost controller?
If using cycling valve, make sure the electrical connector is plugged. A bad cycling valve can cause no boost, but usually you see 0.2bar
Block off the hose going to the WG, you should get boost (lots of it!!!), even if cycling valve is bad.
John
Email
www.vitesseracing.com
Old 01-08-2005, 12:23 AM
  #41
hosrom_951
hosrom_951's Avatar
Fast951: According to todd's sig, he bypassed the CV, but he may have put it back???
Also, if you pinch off the hose from the WG, SLOWLY accelerate. As fast951 mentioned, boost would just be REALLY high (like 22+psi)
Old 01-08-2005, 12:50 AM
  #42
fast951
fast951's Avatar
What type of boost control??
Old 01-08-2005, 12:54 AM
  #43
hosrom_951
hosrom_951's Avatar
That is what i asked in my first post on this thread
Old 01-08-2005, 11:24 AM
  #44
toddk911
toddk911's Avatar
I am running the reliaboost with CV bypassed.
Old 01-08-2005, 11:34 AM
  #45
fast951
fast951's Avatar
Toddk911, thank you for clarifying your boost control method. Many do not update their signature to reflect actual setup, that's why I always ask.
- Block the line going to WG (just unplug it). BE AWARE NOT TO OVERBOOST.
Now your boost is controlled only by the WG's spring. Do you get ANY boost? If not check the followings:
- WG Dump tube when car is cold - if it warms up, problem with WG
- When engine off & cold. Try to manually activate WG by using pressure signal, you should hear WG open.
- Check for leaks in your manifold (intake & exhaust).
- If problem not found, I'll start looking at turbo..
Good luck.
Quick Reply: Your Not Gonna Believe This SHI$$ HELP!!
