JME Camshaft Project
MAn does it smoke from the assy lube spilling on the headers.It also taps a good bit I guess it will take long for oil to penetrate all the bearings and lifters.Good Oil Pressure idle is rough seems to be OK.Did anyone have tapping for a while on start up after a long down time?
When i did the rebuilt on my motor and everything was complete. it smoked like crazy the neighbor called the fire dept. because she thought something was on fire, but all good now beside my boost only going to 5lbs. But to answer you ? yes its normal..
I have the Milledge middle cam, and don't be supprised if your lifters make noise . These cams are not easy on lifters, and will make alot more noise then the stock cam . Lifter life will also be reduce ,by quite a bit.
After the first 20 min drive, new lifters , should not be making noise, but with the milledge cam, I still get some noise.
Rennlist Junkie Forever
The cam noise would depend on which cam is run. The larger the cam lift... the more the noise... because the base circles are smaller than stock.
TonyG
TonyG
"MAn does it smoke from the assy lube spilling on the headers. It also taps a good bit I guess it will take long for oil to penetrate all the bearings and lifters. Good Oil Pressure idle is rough seems to be OK. Did anyone have tapping for a while on start up after a long down time?"
I just finished mine with exactly the same "problems". The smoking very likely comes from installation of the cam tower dripping lots of oil behind the header shields. It took 20 minutes to burn off.
The tapping sounded like lifters, but was really an exhaust head-header leak, which was resolved by loosening the bottom header joint and tightening the header nuts on top really hard (and then obviously re-tightening the bottom joint). If the "tapping" is an exhaust leak, its noise intensity will be a function of the engine load (contrary to lifter noise).
Looks great billgot. I hope to be there soon...
I'm considering the most tame JME cam (PHT 277/XS-14)... Anybody have any thoughts regarding the 15-20hp power claims with an exhaust? How about power delivery?
I have the stock cat back with a 2.5" cat bypass and the standard chips/FPR/MBC. I'll be running 15-16psi.
TIA,
adrial
TIA,
adrial
I need to do my cam soon also... but want low down power, not interested in more revs or peak HP. But I cant seem to get good advice or experience on the right profile for my setup.
