Powerhaus '86 3.0 951 assembly fresh glasurit (pic heavy)
Welp, my 951 has been sitting for years. My mechanic had fallen ill about 2 years ago.
I have my own shop now, and will be doing it myself. Will need pointers along the way, and I will be streaming the build on YT, and IG. Of course will keep this thread updated.
cool where is this happening? what new parts are you putting on and have you ordered anything? parts are getting hard to find nowadays. what about ecu, what are your plans? my 2 951s have the f9 tech setup btw.
good luck! looking forward to seeing this. will you track this car?
All thee parts are bought. OEM everything(for the most part 944/68/24/3). Rogue m-tune. I might put the f9 in. IDK.
I'll list it eventually. It's a long list. I bought nearly every part you can think of new OEM from pelican before they started becoming really scarce.
My shop is near Prescott, AZ. It's just a small warehouse for the 951. I'm calling it my 944 stable.
3 liter build. Was built back in 2008-9. This is the build that sparked the 3 liter registry. Put 50k on it before doing the cosmetic resto. It's been sitting for a few years now.
'89 2.7 944 NA head
Pauter rods
Andial mahle pistons
968 crank
S2 block
Rogue m-tune
Vitesse stage 3 turbo
Spec mini twin clutch
944 manual rack
5 speed with clutch type LSD
KW v3
968 turbo s adjustable wing
968 hatch
931 naca duct(grafted in)
all new trim OEM. Every seal, every grommet, etc, etc.
all new decals
new crest
968 clubsport steering wheel
Still need to order the new interior upholstery
gt-racing front splitter
Elephant racing bushings
Automatic roof delete/manual conversion
OEM Euro rear bumper
Fabspeed 3" straight pipe
'89 2.7 944 NA head
Pauter rods
968 crank
S2 block
Rogue m-tune
944 manual rack
KW v3
968 hatch
all new decals
new crest
heliolps2 (08-02-2024)
Some of the 944 freaks here may remember Powerhaus, and David Raines. This is the last 3.0 951 build David Raines was involved in, and the last of his 944 parts.
As much as you've spent so far, I'd seriously consider getting a new harness and going standalone. Plenty of people doing this nowadays.
heliolps2 (09-30-2024)
At this point, I've ripped a couple 44's apart, but this is the first time I've put one together. I'd be lying if I said I wasn't a little bit intimidated. It's getting really difficult to find a shop to wrench on these any more locally. It's time I started doing all my own work.
Parts from LR:
LINDSEY RACING COMPLETE INTERCOOLER "HARD" PIPE KITS
TPS & AFM HARNESS
SILICONE MASTER HOSE KIT 944T LATE '88-'91
HEADLIGHT CONVERSION KIT 911 / 912 / 924 / 928 / 944
KNOCK SENSOR HARNESS 944T
FOG LIGHT TRIM SET RIGHT 944S2 / 944T
BATTERY / STARTER HARNESS 944 from '85/2 / 944T / 944S2
STANDARD FOG LIGHT LENS RIGHT 944T / 944S2
STANDARD FOG LIGHT LENS LEFT 944T / 944S2
TURN SIGNAL LENS RIGHT FRONT 944S2 / 944T
TURN SIGNAL LENS LEFT FRONT 944S2 / 944T
FOG LIGHT TRIM SET LEFT 944S2 / 944T
IDLE STABILIZER & MISC SENSOR HARNESS
REFERENCE SENSOR HARNESS
FUEL INJECTOR w/KNOCK SENSOR HARNESS
STARTER TO ALTERNATOR HARNESS
TPS & AFM HARNESS
I had been considering the F9(theyre local) or the augtronic from LR.
https://www.lindseyracing.com/LR/Parts/AUGTRONIC.html
