928 Forum 1978-1995
Sponsored by: 928 Specialists
Pulling Engine
Old Mar 2, 2017 | 04:59 PM
  #31
kmascotto's Avatar
kmascotto
Originally Posted by davek9
Just installed one last weekend...
Place a floor or bottle jack under upper bell near the TT, raise the TT&Bell until it touches the tunnel.
Make sure that the two (no longer used) sensor pickups that are attached tho the Flywheel are down at 6:00 position by rotating the Crank (clockwise from front of engine) so they clear the Bell housing.
Lift the Engine up and off the MM's and pull it forward and away form the Upper bell.
Dave... you should try it the other way...way easier
Old Mar 2, 2017 | 06:01 PM
  #32
davek9's Avatar
davek9
Thanks may give it a try, just less to remove and then re-torque, also no need to lift the rear of the car
Also don't those trans bolts require removing the E brake cable from the cross member to get a clear shot at them?
Agree that it would be less wiggling about
Thanks again,
Dave
Old Mar 2, 2017 | 06:40 PM
  #33
awilli6's Avatar
awilli6
I removed the wrong two bolts from trans. I did have to remove e-brake cable to get to them. Heading out of town tomorrow. Will have to get on it next week. Thanks guys!
Old Mar 2, 2017 | 08:25 PM
  #34
Kevin in Atlanta's Avatar
Kevin in Atlanta
Huh?
Old Mar 3, 2017 | 04:49 PM
  #35
kmascotto's Avatar
kmascotto
Thanks again,
Dave
yes, i think there are 2 x 10mm bolts that hold the ebrake cable. I just removed those bolts and pushed the cable aside to access the Trans bolts
Old Mar 3, 2017 | 04:58 PM
  #36
hlee96's Avatar
hlee96
When I pulled my '78 engine, separating the engine from the bell housing was the hardest part of the ordeal. The bell housing parts were basically sealed against each other. I ended up using ratcheting straps to pull the back half enough to use my pry bar in order to finish the job. Best of luck!
Old Mar 3, 2017 | 05:22 PM
  #37
kmascotto's Avatar
kmascotto
Default my success
it was a good day
File Type: jpg
Old Mar 3, 2017 | 07:56 PM
  #38
awilli6's Avatar
awilli6
Great job. I hope to get there on Monday. Will a 750lb engine stand hold our engines?
Old Mar 3, 2017 | 10:33 PM
  #39
hlee96's Avatar
hlee96
Kent, were you so ecstatic that your pants came off?
it was a good day
Old Mar 4, 2017 | 05:32 PM
  #40
Daniel5691's Avatar
Daniel5691
From a prior 'engine weight thread' here on RL...
the 32-valve engine weighs 264 kg dry,
the 4.7 16V engine weighs 261kg dry,
the 4.5 16V engine weighs 245kg dry.
Hope this helps?
Old Mar 6, 2017 | 11:57 AM
  #41
awilli6's Avatar
awilli6
Ok guys. I'm Getting really frustrated with this removal. I checked the two bolts and I had removed the correct two transmission bolts. It won't slide back. I have a pry bar inserted to separate the bellhousing but the pins won't come out and the tranny won't slide back. Are there other tranny bolts holding it in place?
Old Mar 6, 2017 | 12:01 PM
  #42
SeanR's Avatar
SeanR
5 speed or auto?
5 speed needs clutch removed.
Auto needs flex plate disconnected from flywheel.
Old Mar 6, 2017 | 12:06 PM
  #43
awilli6's Avatar
awilli6
It's an Auto. I disconnected the flex plate in accordance with the instructions. I have plenty of space there.
Old Mar 6, 2017 | 12:14 PM
  #44
SeanR's Avatar
SeanR
Then grab a flash light and as you have it raised up a bit, take a look around. About the only thing I can think of that you might not have disconnected would be the engine to chassis ground on the passenger side, but I think something would have busted on it first.
So exhaust, 4 bell housing bolts, flex plate, engine harness, 8 motor mount bolts, A/C, power steering/alternator, coil grounds. If the torque tube is jacked all the way to the tunnel it should come out fairly easy. Nose of the engine up higher than the rear and a bit of wiggling.
Old Mar 6, 2017 | 12:20 PM
  #45
awilli6's Avatar
awilli6
Thanks Sean. I'll give it another once over. If I can't get it out, I'll begin removing everything and part out what I can remove.
