928 Forum 1978-1995
Sponsored by: 928 Specialists
throttle bodies
Old Jan 9, 2017 | 06:44 PM
RFJ's Avatar
RFJ
Default throttle bodies
Would any body know what throttle bodies would fit the 928 and are there any bmw or other cars that would have something on them that would work? thanks for any help? like to ask another question to . Does the spring under the oil pressure sender have anything to do with the oil pressure?Please
Old Jan 9, 2017 | 07:54 PM
Crumpler's Avatar
Crumpler
Ok tell us more, what do you have up your sleeve?
Old Jan 9, 2017 | 07:56 PM
RFJ's Avatar
RFJ
nothing just want to see what my options are hopeing those in the know will respond.
Old Jan 9, 2017 | 11:24 PM
RFJ's Avatar
RFJ
bump
Old Jan 9, 2017 | 11:39 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
You can adapt just about anything with money and time. The springs under the OP sender are for the bypass circuit
Old Jan 10, 2017 | 12:04 AM
RFJ's Avatar
RFJ
op sender i feel stubid
Old Jan 10, 2017 | 12:54 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Hi Ray-
I'm not aware of any aftermarket throttle bodies that are plug and play for either an 85 Euro S or an 86.5, and I'm not sure that the throttle body would be the limiting factor in airflow in either car. If you're looking for more power I'd start with exhaust and/or Ken's S300 chips for the 86.5
Old Jan 10, 2017 | 10:16 AM
RFJ's Avatar
RFJ
Originally Posted by Rob Edwards
Hi Ray-
Hi and thank you. I already have a 3.5 inch single exhaust and kens chips on the 86.5 so i am in the process of putting an 87 motor in the 86.5 now . one problem i am having is the top oil cooler line snapped off and took about 1/2 of the threads with it,going to see if i can tap it a little deeper i hope. I see all these 928's with tbs on them and the power they make with some decent cams so i thought i would give that a try. that set up with a turbo such as Colin has on his i would think that would do it. best,Ray ya comments please
Old Jan 10, 2017 | 01:21 PM
Rob Edwards
Archive Gatekeeper
Ah, you mean individual throttle bodies (ITBs)? There are a couple of very good threads on them for S4 motors, here are a couple for starters:
https://rennlist.com/forums/928-foru...32v-itb-s.html
https://rennlist.com/forums/928-foru...age-a-gts.html
Old Jan 11, 2017 | 09:06 AM
RFJ's Avatar
RFJ
I knew i was at the correct door thank you sir off and rolling.
