928 Forum 1978-1995
Sponsored by: 928 Specialists
Cayenne COP connectors
Old Aug 22, 2016 | 05:15 AM
ramcram's Avatar
ramcram
Default Cayenne COP connectors
I've seen the answer to this but now I search for hours and can't get it again.
I want the 4 pin connectors for the Cayenne COPs. I bought 8 that look perfect but the pins are slightly too far apart.
Someone listed the Kostal part # but I can't find it.
Can anyone help?
Old Aug 25, 2016 | 04:44 AM
jheis's Avatar
jheis
Rule of usage: when using an abbreviation (or acronym), write the full name followed by the abbreviation in parentheses at the first mention of the name.
I have no idea what you are talking about (and since no one has responded to your question, apparently no one else does either).
Old Aug 25, 2016 | 05:01 AM
ramcram's Avatar
ramcram
Default Cayenne COP (Coil-On-Plug) 4 pin connectors
I want the 4 pin connectors for the Cayenne COP (Coil-On-Plug). I bought 8 that look perfect but the pins are slightly too far apart.
Can anyone help?
Old Aug 25, 2016 | 10:33 AM
Wisconsin Joe's Avatar
Wisconsin Joe
You might try in the Cayenne forum.
I've never heard them called "Coil-on-plug" before.
Always "Coil packs".
Old Aug 25, 2016 | 12:01 PM
hans14914's Avatar
hans14914
They are just darn expensive making them almost unusable. Its a dealer only part, and something like $50 for each plug and pin set.
It was cheaper for me to buy take-off engine harnesses when I looked at using them.
FYI, the 2.0T Audi Coils work just fine with our engines, all you have to do is remove a little nub cast into the plastic to retain the boot - it takes just a couple seconds with a hack saw. Those connectors are super cheap through many sources, but VEMS USA is the easiest.
I did design a boot years ago to adapt them to our valve covers.
Old Aug 25, 2016 | 02:41 PM
BC's Avatar
BC
I posted the part number like 8 years ago. I can't find it on here, maybe you will have better luck.
Old Sep 1, 2016 | 05:02 AM
ramcram's Avatar
ramcram
Thanks guys. I might just make my own, or just open the pin slots in the ones I've got.
The connectors I have look perfect and the 'mouth' and seal are fine but they have a very slightly wider pin spacing.
Old Sep 1, 2016 | 09:43 AM
Lizard928's Avatar
Lizard928
The ones you have are likely for the VW COP units.
I gave 8 cayenne units I might be willing to sell.
What are you planning to use to fire the COP units?
The cayenne units are a real PITA to get working properly. Not many brains will fire them properly.
Old Sep 2, 2016 | 04:16 AM
ramcram's Avatar
ramcram
I have 8 cayenne units I might be willing to sell.
I'd love to buy them. I've been thinking of removing the pins from the set I have and using a hot, flat blade to widen the holes in the holder. They are only out by a fraction but it's enough to prevent them from connecting to the coils.
I bought a VW C-O-P to see if it fitted the connectors I have but it's the same deal, not quite.
I plan to use a Link G4 Thunder EMU. I've spoken with them and they assure me that this unit will work the Cayenne units.
This G4 Thunder model supports twin E-throttles, 2 knock sensors and 2 WB O2 sensors. All of which I want to use. They claim to work with any E-throttle and any E-pedal.
The Beru C-O-P I have's outer pins are 17.6mm centre to centre and I think each pin is about 5mm centre to centre. It's hard to measure them down inside their tube, so take my measurements as a guide only.
File Type: jpg
File Type: jpg
