did a CE panel refresh (Actually a few weeks ago - just getting caught up now in posting Some issues that came up - I can't seem to find a wiring diagram anywhere for a 1980 Euro "s". So I was hoping the gurus might have an idea of what's going on. (The only electrical issue I have at the moment is no HVAC blower. - all other system appear to be in working order). Car also has factory alarm but not sure if it's working or disabled (no jumper at Z plug BTW).
Issue 1 - there is what appears to be a blue factory wire with a yellow/greenish stripe from CE that's taped off. Any idea what this wire is supposed to go to?
Issue 2: At the CE panel there is a Red wire/Yellow stripe that's spliced with a brown wire that goes through firewall and connect to a similar red/yellow strive wire just prior to entering the 14 pin connector. Not sure what that wire carries or why it was spliced in such a manner.
The wire under the electrical tape is bown, goes through firewall and to 14 pin
through firewall....
And to 14 pin - spliced back to the red/yellow striped wire!?@?
Issue #3: What is this 4 wire plug and then black connector supposed to attach to - it looks factory and has a length that looks like it could reach console - any ideas as to where it should attach? Look familiar to anyone - comes out of factory harness in passenger footwell.
white connector with four wires and black wire connector behind.
What the early car diagrams lack in clarity, they make up for in simplicity. And there is a 'legend' of sorts (including connector and ground locations, and wire colors) on page two of the pdf that GlenL linked to above.
