928 Forum 1978-1995
Sponsored by: 928 Specialists
Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
Old 04-12-2016, 07:14 PM
  #631
Ducman82
Ducman82's Avatar
the design "hard part that is already done" is still for another motor. now "IF" you can cut off the runners, and the length added is right for our motors, and matches the internal dimensions and it works out, that would be something. maybe find a CAD file of this, and virtually do the cut and chop job and see if it is even able to be "correct" for a 32v. for sure won't fit a 16...
Old 04-12-2016, 07:23 PM
  #632
mark kibort
mark kibort's Avatar
im thinking of buying it.. found another newer one for cheaper too.
why do you say the 16valve is a no go? due to the shape? the shape looks like the S4 runners, no? i wonder how close in size.
the challenge is cutting them off and whats left, either connecting to the short manifold of what carl has made , or something else , maybe 968 manifold?
then, seeing if you can spread them out by about 1/2" each and spread the side to side spacing by about 1-1.5 " as well.
Old 04-12-2016, 08:09 PM
  #633
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
Originally Posted by Hacker-Pschorr
The Dynojet we've been using in Green Bay for the past 10+ years is a steady state AWD unit with twin eddy current brakes.
https://www.dynojet.com/products/dyn...er-224xlc.aspx
That's what it takes, to get them close.
Then you need to test them in the real world.
Old 04-12-2016, 08:16 PM
  #634
mark kibort
what about these 968 intakes as the lower manifold ? are the same since the 969 and S4 heads are near the same??
Old 04-12-2016, 08:18 PM
  #635
GregBBRD
Former Sponsor
GregBBRD's Avatar
Cut off the top piece, separate all the runners so that they fit on the 928 heads, weld up the gaps, modify the top as needed (wider or longer), weld it back on. Maybe you need two of them to make the top longer/wider and get 8 individual runners (if the runners are attached to each other...you could harvest some from each manifold.)
Those tapered rectangular runners are awesome...it certainly should flow crazy amounts of air!
Old 04-12-2016, 08:29 PM
  #636
Ducman82
Ducman82's Avatar
without seeing it plopped on top of one of our engines, i would say the legs would be uber funky to do for a 16v. grab one up and lets get to work!, see how she fits.
Old 04-12-2016, 09:18 PM
  #637
OBehave2.0
OBehave2.0's Avatar
Originally Posted by V2Rocket
got a collection of manifold flanges in that pile?
S-4 and S-3. How many you need?
Old 04-12-2016, 10:31 PM
  #638
GregBBRD
Former Sponsor
GregBBRD's Avatar
968 intake ports and manifold are gigantic compared to an S4....there would be a substantial ledge which the incoming airflow would hit, if a 968 intake was bolted on.
Probably not the best thing....
Old 04-12-2016, 11:01 PM
  #639
mark kibort
I was under the impression that the heads were near the same. intake ports are much larger.. that ledge would not be good. or...........got to port the 928 heads to match... sounds like more easy stuff.. (ugggg)
Old 04-12-2016, 11:04 PM
  #640
mark kibort
hacksaw or my usual Axe.... wonder what would work best.
those runners do look pretty nice though.. It just keeps calling me to buy it and hack off its legs!
Old 04-12-2016, 11:05 PM
  #641
mark kibort
now we are talking! so, welding up a tube to these might be the best way.
why would it be any more funky on the S4. isnt the spacing still wide like the S4?
Old 04-12-2016, 11:08 PM
  #642
GlenL
GlenL's Avatar
Wouldn't ya port that to match and get a touch of venturi right before the valve?
Old 04-12-2016, 11:27 PM
  #643
mark kibort
yeah... that sounds like a good idea if you could get a smooth transition, no?
but, from gregs perspective... much more work.. he knows im trying to make this a bolt on affair. the real question is the size of the AMV8 ports out of that intake
Old 04-12-2016, 11:46 PM
  #644
GregBBRD
Former Sponsor
GregBBRD's Avatar
There's not enough metal in the 928 head casting to open the ports to 968 sizes....
Old 04-13-2016, 03:58 AM
  #645
Strosek Ultra
Strosek Ultra's Avatar
Do not increase the area of the 928S4 intake ports, you will loose air velocity. The ports at the gasket surface are actually too large unless the heads are sitting on a high speed 7 liter engine having 42mm intake valves.
Åke
Quick Reply: Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
