928 Forum 1978-1995
Sponsored by: 928 Specialists
Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
Old 04-11-2016, 03:58 PM
  #586
mark kibort
mark kibort's Avatar
or some need to open their mind a bit..... most of the thoughts are pretty obvious. but ill try and be more clear!
Originally Posted by Rob Edwards
Came across an interesting data point. If you text mine the archives for the number of times MK has said 'you missed my point', Guess how many separate instances?
145. Needs to work on his point, clearly.
Old 04-11-2016, 04:32 PM
  #587
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Mongo
LOL, the Slivovitz isn't real in the states. My uncle brews the real stuff in Croatia.
The real ones come from the Serbian side and I distilled it with my grandfather. The beer you guys have in the US is horsepower too.
Old 04-11-2016, 04:59 PM
  #588
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Serb and 'real' should not be in the same sentence. (kidding of course)
Quite honestly and ironically, we have a friend who is Serbian and does the same thing. Politics and history aside, my uncle and him have shared recipes. He also lives in Croatia and is about 2 hours away from my uncle's distillery.
Old 04-11-2016, 05:22 PM
  #589
mark kibort
so, not to beat a dead dog, but is it possible to take an intake like the AM V8 intake and lap off the legs, and weld up some legs that fit the 928 head ports? I wish i was a aluminum welder and fabricator. I would love to take on that project.. i bet it would work. used intakes off the AM v8 are in the 2k range.
Old 04-11-2016, 06:18 PM
  #590
Ducman82
Ducman82's Avatar
what are its dimensions?
Old 04-11-2016, 06:29 PM
  #591
mark kibort
the ports seem to be 10.5" apart side to side.. the row of all the runners are about 12" long, with 4" between each runner and the entire intake is about 22" long and the entire intake is about 8.5 tall from the surface of the head
using the same measurements... the hight of the intake sytem is the same about 8-8.5" the S4 has the row of intake runners at a length of 14 " vs the AMV8 intake of 12". the S4 is more like 12" port spacing side to side vs the AM V8 which is 10.5.... and the length of the s4 intake is much shorter as it doesnt include the same TB mount.... so , 14" , the length of its row of ports, is its length. the body is a little shorter than that.
edit: the best way for it to fit, would be to be pointed rearward and the TB would just be in the AC area under the base of the windshield, with room for a 9 degree elbow and a large cone filter.
Old 04-11-2016, 07:28 PM
  #592
V2Rocket
Rainman
V2Rocket's Avatar
You would be way ahead taking the design features of the AM stuff, and making a totally 100% custom manifold using it as a "scale model".
Cutting up AM parts is bad due to the cost of the parts, and the fact that the AM stuff is bound to the same considerations (restrictions or limitations) as the 928 intake would be...namely, off-idle power, ease of cruising, decent MPG, and emissions compliance above all else.
You won't make 100hp or 50hp without throwing these ideas out the window, partially or wholly.
Old 04-11-2016, 07:41 PM
  #593
Imo000
Captain Obvious
Super User
Imo000's Avatar
Yes it's possible.
Old 04-11-2016, 07:44 PM
  #594
Imo000
Captain Obvious
Super User
Imo000's Avatar
I gew up in Serbia (was Yugoslavia back then) but I'm not a Serb.
Old 04-11-2016, 08:05 PM
  #595
mark kibort
actually, the hardest part, it seems is the intricate design of the runners. this AM intake has that done for you and has none of the limitations that the S4 intake has . MUCH larger runners, and as GB proved, even putting a 85mm TB on the S4 intake, didnt give any gains.. its VERY restrictive and has major issues at high RPM and flow rates. the AMV8 intake would probalby have none of that. the only draw back is that you lose low end flappy torque, which racers and HP geeks wont care much about (nor the MPG part of the equation)
Again, i bet its a 30hp bolt on affair for the S4 and a 50hp bolt on affair for the strokers
Old 04-11-2016, 08:28 PM
  #596
Ducman82
Ducman82's Avatar
flow and runner designes fro that intake are pretty different. but if one of fab it and actually test it, it could be the runners and plenum might cause problems with. just like if you bolt a single plane intake on a car after having a dual on there... same runner lengths, but a diff beast.
are you going to pick on up and do some planning?
Old 04-11-2016, 09:33 PM
  #597
dr bob
Chronic Tool Dropper
dr bob's Avatar
Do it! And let us know what gains you see with no other changes.
Old 04-11-2016, 10:35 PM
  #598
jcorenman
jcorenman's Avatar
So an intake that is designed for a 4.3L engine works equally well on a 6.5L?
I didn't know that, thanks! And it is especially great to hear that size doesn't matter! !!
Old 04-11-2016, 10:52 PM
  #599
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
Could be....give it a try!
Just remember that once the raw intake manifold is done, there's an entire list of other things that need to be made to work, also.
It seems so simple, until you actually start having to design and fabricate all the pieces. I'm guessing that 2/3 of the cost for my manifold will be the actual manifold. The rest will be consumed by throttle linkage, fuel rails, injectors, dampers, fuel pressure regulator, fuel pump, wiring, plumbing, etc.
And then there's the whole tuning thing to optimize all the changes. (Keep in mind that adding 50 more horsepower to your stroker will maximize the stock air flow meter.)
Yes, I'm sure you will say "I'll just use what I have." But the reality is way different. You need bigger injectors to make more horsepower. That requires more fuel delivery. More fuel delivery requires different fuel pressure regulator to be able to return the excess fuel at low loads (or suffer the problem with overheating the fuel....this Forum is loaded with posts from people that have had this problem, but have no clue why.) Now that the injectors are much larger, there are brand new problems with the pressure waves caused by batch firing the injectors (Rob Edward's engine "shook" the fuel lines so much that it concerned us that the fuel lines were up to the task of containing the surges.....and we were forced to make some changes.)
Simple?
I'm a far cry from a novice at this stuff....I can design and fabricate virtually anything, without leaving my shop. Note that I'm three years into this project. Granted, I need to make a living and can't devote every minute to this....but I've personally got hundreds of hours into this project. And the piles of scrap attempts and scrap pieces would amaze everyone.
Simple....it is not!
Old 04-12-2016, 12:03 AM
  #600
Ducman82
Ducman82's Avatar
Ya, it is a nice large pile. i keep tripping over the boxes of test parts!
Quick Reply: Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
