Cam Gear Alignment?
Yes I did use sealant on pump. Yes I did tighten bolts to pump as specked from Porsche. And radiator fluid leak is odd because I just removed, superficially cleaned and installed back on.
RVII
RVII
The transmission cooler problem looks somewhat obvious although why it should fail is the interesting bit- these are not high pressure rated coolers like the engine oil cooler circuit. Sounds as though oyu need to give 928 International a call on that one- quite common availability and not too expensive - just a PITA.
The water pump failure is a bit more worrying and presumably you are sure of what you are reporting- one assumes no connection with the ATF leak. Edit: The tensioner mount thread is reportedly prone to leaks if not sealed after a change out if that is what you have done [as I seem to remember]. Obviously you need to determine the source of the leak and that probably involves more tear down not really a big deal assuming you have done this previously. Annoying - yes!
Just be patient as you get to the bottom of this issue and you will soon be laughing this off all being well.
Regards
Fred
Regards
Fred
Last edited by FredR; Jan 28, 2016 at 11:47 AM. Reason: Clarification on the potential leak path
I've never seen a failure of the trans cooler. Maybe the source of the engine coolant leak is obvious. If not, it would be best to fix/replace the trans cooler and start the car to make a more thorough observation of the engine coolant leak before you tear things down. Bad pumps can leak from the pulley shaft seal, but I've not encountered a new or rebuilt pump with a bad seal yet.
I'm sorry you ran into these surprises at the end of your first TB/WP job. This is not a simple procedure, and I guess it was more surprising that yours seemed to be going so smoothly. My first one took me days and days and involved a lot of hair pulling mishaps.
Bummer!!!!
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
