928 Forum 1978-1995
Sponsored by: 928 Specialists
Cam Gear Alignment?
Old 01-10-2016, 11:01 AM
  #76
FredR
FredR's Avatar
Ken,
As Malcolm says please confirm your engine is locked at 45 degrees before top dead centre.
with the crank in this position you can rotate the cams as many times as you wish. One revolution of the camshaft gets you back to where you were previously relative to the crank position. The alignment mark on the cam sprocket should be 3 teeth before the marks align then you string the belt.
We recommend making a mark on the tooth adjacent to the casing index notch prior to moving the cam sprocket.
The train should not be moved backwards once the belt is strung. As a matter of course I do not turn the cams backwards unless it is a small amount to pick up the spring movement.
When moving the cam only do so using the large hex washer not the cam ut
Rgds
Fred
Old 01-11-2016, 12:24 AM
  #77
mark kibort
mark kibort's Avatar
Originally Posted by kkgmgcooke
Hi. My timing belt if off and I am removing my cam gears and recoating them...but this is not the source of the question.
I rotated the right cam and it jumped clockwise about 1/8 turn. So, not wanting to go backwards (and not thinking about it), I turned the timing gear all the way around (i.e. another 7/8 turn clockwise) to re-align the marks I made on the cam gear housing with the gear. Now, I'm thinking that perhaps I created an issue with valves being mis-aligned (?) since turned it clock-wise a full turn?!?!
Is that OK or do I go counter-clockwise 1 full turn to the original location before it jumped. Or, do I need to rotate it clockwise more to re-align things?
Please help this newbie
Ken
the cams be rotated any direction.. the direction concern is only when the belt is strung.. (causes incorrect forces the tensioner roller)
so, if the belt is off, there is no problem moving the cams a few degrees , either way. but if the crank is not set at 45degrees btdc, then you can only move them a 4-5 teeth in any direction. you cant go 360 degrees or you will have valve to piston contact. (possibly. because when not running the hydraulic lifters are not fully pumped up)
Old 01-11-2016, 10:49 PM
  #78
kkgmgcooke
kkgmgcooke's Avatar
Cool
thanks everyone. I slept better after this.
Old 01-16-2016, 05:43 PM
  #79
Ricardo Vega
Ricardo Vega's Avatar
Hey guys, trying to finish up my TB/WP project. Been busy and haven't had all the time to finish but I'm stuck at the cam gear adjustment portion. I've got my took from Porken for cam gears. But I keep adjusting it to get a perfect 0* on both banks and it's always off by 1* when the othe is at 0*.
Can't seem to get both at 0*. Any suggestions?
I'll attach pics to it so maybe someone can see what process I'm stuck on.
RVII
Old 01-16-2016, 05:45 PM
  #80
Ricardo Vega
Passengers side is 1* behind.
Drivers side is perfect at 0*.
Old 01-16-2016, 05:51 PM
  #81
Ricardo Vega
It seems odd to me that I need to squeeze both cam gears to get to zero but with the little slack belt has it would go back to the setting. Can someone fill me in why it's a bit off and if it would even get to 0* on both ends? Thanks.
RVII
Old 01-16-2016, 06:05 PM
  #82
ROG100
Basic Sponsor
ROG100's Avatar
General consensus is to set at -2 Right side and 0 left side.
Old 01-16-2016, 06:54 PM
  #83
Ricardo Vega
General consensus meaning it will never be at 0*-0*?
It will only be at 0*-2* or 2*-0*?
RV II
Old 01-16-2016, 08:34 PM
  #84
bureau13
bureau13's Avatar
Is the -2/0 still true if he's using the PKT? I thought the 2 degrees retard was due to the engine being cold and the expected impact of it warming up...doesn't the PKT counteract the change in tension? Or not...
Old 01-16-2016, 09:59 PM
  #85
Ricardo Vega
The manual for the PKT recommends 0*-0*. But I can't get it there. And now I'm told 0*-(-2*) and now it's confusing even more.
Can some please tell us an answer and the reason why this is wrong or right?
RVII
Old 01-16-2016, 10:18 PM
  #86
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,341 Likes on 509 Posts
32V’r
Each hole is one degree, going in a zigzag pattern. The center, raised hole is zero. Left and down from the zero hole is one degree advance.
When looking at installed tool, CCW of zero hole is advance, CW is retard.
A good basic setting is:
Left: 0°
Right: 1-2° retard
The retard on the right side is to compensate for engine expansion when warm.
This is from Ken's web site.
Page two here.
http://www.liftbars.com/docs/32VrManual.pdf
Can't tell if this is different with the PKT.
Old 01-17-2016, 05:22 AM
  #87
FredR
FredR's Avatar
Gents,
May I politely suggest we talk about 1/4 and 5/8 or port side and starboard side rather than "right and left" -urrrgh!
The 32VR is quite precise as to what is recommended and on a cold motor there is a two degree difference between set points on each bank. There is also another possible correction for whether it is a new belt or a "stretched" belt.
Ken articulates this reasonably well but to be fair, it is a little bit confusing. My approach is to use the two degree difference between banks and then check again after running the belt in [1000miles] and then make an adjustment if needed whilst tightening the cam belt a tad due to the initial stretch.
I can more or less guarantee you will not notice any difference in performance given the range of adjustment we are talking about here.
Rgds
Fred
Old 01-17-2016, 10:57 AM
  #88
Bertrand Daoust
Originally Posted by FredR
...I can more or less guarantee you will not notice any difference in performance given the range of adjustment we are talking about here.
Rgds
Fred
+1.
You're very close to "0" to me
And if that's what you want, don't worry, you're good.
To resume, I would put the 1/4 side gear to "-2" (or about) and the 5/8 side to "0".
But that's me.
Keep up the good work.
Old 01-19-2016, 12:06 AM
  #89
Ricardo Vega
Thanks guys!
I'll keep y'all posted on progress.
RVII
Old 01-28-2016, 01:44 AM
  #90
Ricardo Vega
Not a good day at all guys. Put car back together, long story short. Started car and the transmission radiator started leaking when I turned key. Sprayed my garage door and front end of car and then radiator fluid started leaking from under water pump area.....do you know how much I wanted to cry?
Transmission fluid........
The leak, which it never had before and I never damaged at all....odd.
Radiator and tranny fluid.........
Quick Reply: Cam Gear Alignment?
