Piston rods bind at the crank during assembly
I am assembling a 1990 engine and have encountered something that has stopped me in my tracks while inserting the pistons.
Inserted and hand tighten the # 1 piston's cap. Crank spins with little effort.
Inserted the #5 piston and the rod end binds against the #1 rod and creates a lot of resistance while trying to turn the crank - tighten the #5 rod cap and the crank will not turn.
The engine was fully disassembled when I got it and the piston order was lost. I have assembled an other 928 engine (86 s3/hybrid) and had none of these issues. I assumed all rods are manufactured to same width. Bad assumption?
Everything is new - thrust bearing, rod end bearing, nuts and piston rings. Well lubricated.
Any guidance is appreciated. I am tempted to mic the rods.
I suggest checking on this. One thing's for sure: the wide sides don't all point the same way. The rods on each side are assembled differently with respect to where the piston notches are.
So, one page says the narrow sides face each other and another page talks about the piston facing another. Wow. I assumed the rods have never been separated from the pistons. So, the next question is do I need to flip the rods 180 dg?
Yikes.
I wouldn't assume anything. Look through the manual carefully, there's enough pictures you can reference to allow you to see if the pistons are on the rods correctly. Or like Mark said, post some pics.
