928 Forum 1978-1995
Sponsored by: 928 Specialists
86 S2 Hydrolocked with fuel???
Old 10-17-2014, 05:11 PM
  #46
Livio928
Livio928's Avatar
This is an interesting thread I am following closely. I may have a somewhat similar problem albeit my injectors are flooding like yours, but I definitely have excess fuel in the cylinders, but not getting proper spark. I will try to look at LH as Dave is suggesting to see if that may be my problem. Engine was re-assembled and the car hasn't run in 4 1/2 years. I am keenly waiting on reports from Roger as to whether it is an LH problem or not. I think mine may be due to the lack of proper spark.
Old 10-17-2014, 11:14 PM
  #47
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by ROG100
Hi John,
MAF was fire damaged and has now been fixed.
"thermal runaway mode" so could this have been the reason why the car flooded? However the cylinders were filling up with the car not running.
This picture is showing how full the air guide was before the video. A LOT of gas.
That's crazy!
To get that lower plenum full of fuel, at lest one of the intake runners had to fill and overflow backwards into the plenum!
Old 10-17-2014, 11:22 PM
  #48
SeanR
SeanR's Avatar
Originally Posted by DR
Sean, Roger,
For giggles, open up both of the engine computers and check the eproms closely. First check to see if they are non-stock, secondly check for a cracked and/or broken pin...or bad solder joint on the eprom socket(doubtful).
Sorry it has been so long that my failing memory can't remember exactly which pin to check, but one specific bent/broken/cracked pin will do this exact scenario you have experienced.
Don't ask me how I know this, but I do have the T-shirt.
Cheers,
Dave
Thank you Dave, things are odd on this one. You've had more experience with these than we do, so any thing you can add to assist is greatly appreciated.
Originally Posted by GregBBRD
That's crazy!
I didn't believe him when he called me as there is no fvcking way that can happen, in my mind, with out a hose shooting right in to the intake. I about crapped myself when I saw it for myself. The pump had to have been running, with open injectors for so long that it was doing this as Roger had stepped away from the car. This might be one of the reasons this thing was on the salvage lot due to fire.
This "save" has a few fun issues to sort out and I think we've got a game plan, but you know how that changes. Bound and determined to make this POS a daily driver now.
Old 10-18-2014, 12:05 AM
  #49
jeff spahn
jeff spahn's Avatar
Originally Posted by OTR18WHEELER
. . . snip
Short story long, the engine ran fine afterwords, but had a slight vibration, come to find out later, the hydrolock episode actually bent one of the connecting rods.
I have always wondered if I had a slight bend in one of my connecting rods after I tried to start the car and it was hydrolocked. It never has seemed to idle as smooth as a Lexus V8 or a new suburban for that matter, but that could be this engine design and I am crazy.
Old 10-18-2014, 12:21 AM
  #50
928 at last
928 at last's Avatar
Default Hmmm....
1). Possibly. When mine is in the right mood, (not often, but it does happen) you can barely tell that it's running. Never hydrolocked to the best of my knowledge, which admittedly, is limited on a good day.....
2). Nothing to do with the design of the engine....sorry.
3). Yes, you are....but that's an entirely unrelated issue.
Old 10-18-2014, 01:35 AM
  #51
SMTCapeCod
SMTCapeCod's Avatar
That thing have a cold start valve? Or is it supposed to have one that was somehow replaced with open pipe? ;-) j/k
Old 10-18-2014, 02:07 AM
  #52
Hilton
Hilton's Avatar
I'm wondering whether a failed FPR (this car has two pressure regulators from memory? I think its the LH-based Euro's which do?) could dump that much fuel into the throttle body through the vacuum lines with repeated start/run/shutoff (such as when moving the car around a driveway to make space).
Each startup could re-pressurise the fuel system, and then bleed out into the throttle body, until it was totally full and burped.
Old 10-18-2014, 02:26 AM
  #53
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
...just a side note, the hydrolock I mentioned was due to driving into high water, so the engine had a few more rpms than just cranking over.
Old 10-18-2014, 10:52 AM
  #54
jeff spahn
jeff spahn's Avatar
Thanks OTIS () I just tried to start it and it wasn't running.
Old 10-18-2014, 06:22 PM
  #55
Hilton
Hilton's Avatar
Just re-read Roger's post. He's jumped the fuel pump for 5 mins before trying to start. If one of the pressure regulators or the dampener has failed with a hole in the diaphragm, that would just be 5 mins of pumping fuel into the throttle body. Failed FPR is more likely than LH IMO - that doesn't mean that failed LH/EZ-F aren't candidates, just that I'd play the percentages and check the more common suspects first.
Old 10-18-2014, 06:40 PM
  #56
ROG100
Basic Sponsor
ROG100's Avatar
Hilton - Very possible and I have already changed the two fuel pressure regulators and the damper. For grins I will pull a vacuum on the originals so see if they were bad or not.
Old 10-18-2014, 08:25 PM
  #57
Imo000
Captain Obvious
Super User
Imo000's Avatar
Just pull the vacumm lines off the dampeners and jump the pump.
Old 10-19-2014, 11:28 AM
  #58
ROG100
Basic Sponsor
ROG100's Avatar
I found that the engine was hydrolocked after I changed the fuel pressure regulators and damper. So it is possible the air guide was filled from a leaking regulator.
However the filling of the cylinders was AFTER the regulators and damper were changed.
Could not check the regulators and damper as the trash (dustbin) man has been.
Old 11-12-2015, 11:41 PM
  #59
RennPartsDirect
Former Vendor
RennPartsDirect's Avatar
Roger- Any worthwhile results to mention about this issue? Has it happened again to that engine? Did you have to do any deeper repairs beyond the fuel delivery system?
SS
Old 11-13-2015, 12:47 PM
  #60
ROG100
Basic Sponsor
ROG100's Avatar
As always - Life and other cars - have got in the way.
Sean is going to make me a new injection harness and I have a set of 24 Lb 4 hole injectors with GB adapters ready to add.
Hopefully that should correct the issue.
Quick Reply: 86 S2 Hydrolocked with fuel???
