super blue banned?
Seeing if I can buy a couple off of eBay. I have one unopened and one opened. Have to switch out the rest of my brake lines to steel so I'll definitely need it.
The gold one has the same specs I believe as blue. Just the color. Maybe they can just convert blue to clear. I liked the blue because I can tell when the old fluid is purged.
Apparently if it isn't clear or amber you can't see impurities and water in the system necessitating that it be no other color that could "mask" these problems and prevent brake system failure.
Purchase from an overseas supplier, perhaps?
Not what I expect from a fellow Brit who is used to endless queuing in an orderly fashion!
It should be obvious there is a real danger that we are going to confuse it with that blue stuff they use to flush aircraft crappers! Maybe that stuff works as hydraulic fluid- maybe it is ATE blue and they just do not want us to know the truth. Then there are those things you stick in the "Can" to make the water blue - seems you can only "blue in the loo" not to mention "Blue movies"- I guess they are now under threat as well.
Switching between ATE Blue and ATE Golden to differentiate when you have completed the flush must surely be a very dangerous thing to do [sic].
Now I hear that beetroot is being banned because it turns your poo red!
Oh- and someone tell Worth to drink more water- he's dehydrated!
Got to run..... the boys are after me for being left handed!
Regards
Fred
I ordered two more cans off Amazon yesterday and my order shows shipped with a tracking number. Should be here tomorrow. YMMV, seller only has a couple left:
super blue banned?
Seriously, waiting for a color change as an indication of when to change brake fluid may not be the best policy.
Just bleed & flush the brakes (and clutch if you've got one) every couple of years.
