928 Headers
OBX seems to be cheap Chinese stuff that's flooded Ebay. I assume someone shipped a set of MSDS to China and the boat just arrived back.
Devek made flanges with both hole patterns, the lower 2 looked like a figure eight because of the difference in position.
The Devek idea was the installer to cut off the top part of the flange for use on 16Vs.
I didn't want to do that since a 32V was going in there eventually so I made spacers that kept that top flange from hitting so I had no need to cut anything.
The other 16v-32v difference is the ports are centered at each cylinder in the 32v but offset to one side in the 16v because of the nature of 2v heads having an intake and exhaust next to each other.
That means that the collectors will be forward on one side and rearward on the other.
That difference makes the piping that bolts to the collectors be in different positions from 16v to 32v but I found that everything else cleared around the steering etc.
BTW, in theory you could open up the lower 2 holes and use stock manifolds from 16v to 32v and vice versa but in reality the holes would break out making this impossible. Only the Devek flanges have enough material for both sets of holes.
His response was Pls read this link for the answer to that question.
http://forums.pelicanparts.com/porsc...all-month.html
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
1.6" OD primaries
3.0" OD collector
2.3" OD outlet
0.4" CNC machined flange perfect fitment
16 gauge (1.5mm) runner wall
304 stainless steel mirror polished finish
Mandrel bend smoother flow
Individual port increase output and efficiency
Great throttle response with great sound
Dual Tig welded for durability
Accessories on the photo is included
Acutal photo of what will be send out
See disclaimer on the bottom of this page
OBX backed lifetime warranty against manufacturer defects
Third link - OBX Header Exhaust Porsche 928 USA / European Euro 32V-GT
Now before folks start getting all hairy arsed let me explain. Several folks have offered this spec of headers [assuming it is the MSDS design] and yet I have never seen a before and after dyno comparison specifically for the 32V variant. I have read positive things when fitted to 16V motors. The Devek headers definitely do wonders - I have seen the evidence but they have bigger primaries and therein lies the trick or so I understand.
I have no position on this- just looking for hard evidence here. Even the Devek header design has or had some potential issues with heat if I remember correctly.
Regards
Fred R
http://www.epi-eng.com/piston_engine...technology.htm
The effect of a straight collector is generally a very peaky tuning, in which the lengths of the primaries can be varied to produce a 'rocking' effect of the torque curve around its peak. Lengthening the tubes raises the portion of the curve below peak and reduces the portion above peak torque; shortening them has the reverse effect. Various strategies have been devised to spread the effect of exhaust tune over a wider RPM band. These strategies typically involve generating additional waves of smaller amplitude (additional, smaller steps, for example) or attempts to increase the width (duration) of the pulse at the expense of pulse amplitude by using a tapered section to extend the area change over a longer period of time.
The Pipemax says me that MSDS collectors are way too short to give peak torque under 6000rpm. Therefore no torque increase for stock 32V engine.
That was perhaps done for catlysator fitment reasons for 32V, the OB headers and colletors are longer.
The primaries are 1,6" which is good for from stock to around 500hp. The lenght of primaries gives the pulse tuning effect something after 5500rpm. This is too high for stock cams as they stop producing more flow around 6000rpm. Even the primaries are varying sizes, they are quite close to pulse harmonics to each other to work just fine(not perfect, but remember the price...).
The solution for getting torque is to replace the old style straight collectors with conical or full merge collectors. I don't know who made the headers sold by Mark K. but if you look them, they do not have straight collectors like MSDS.https://rennlist.com/forums/928-foru...-for-sale.html
I removed the straight collector from my MSDS headers and welded conical 4-1 collectors with bullets in place. http://www.coneeng.com/exhaust_system_kits.html
They gave me nice broad torque boost for my S4 with Colins stage II cams. I also sent email to Martin Schneider, but he newer answered to my questions and ideas. i didn't take any dyno numbers as my project is still ongoing, but I was happy with my assometer findings.
Why not you guys ask OBX to make one with similar collectors for testing. They will then be wery interesting product also for stock 32V owners
The MSDS product in the link i was given to answer my question, looks to have different flanges than the OBX product.
Just as many questions as when i started.
Is there another manufacturer still making a good tested header for an early 16V motor like mine?
I like the idea of trying to get an optimal custom design.
Regards
Fred
