928 Forum 1978-1995
Sponsored by: 928 Specialists
View Poll Results: Where is the best place for the cupholder on a 928?
Screwed into the side of the console
13
22.03%
Clipped into window seal
1
1.69%
Co-pilot's hands
8
13.56%
The floor
4
6.78%
External garbage can
17
28.81%
Other. Please explain
16
27.12%
Voters: 59. You may not vote on this poll
Correct cup holder
Old Sep 11, 2012 | 10:59 PM
  #61
fraggle's Avatar
fraggle
nice build PorKen!! Can you flip us some details? that coin holder isn't that useful when the tolls are all measured in dollars.
Old Sep 11, 2012 | 11:05 PM
  #62
bronto's Avatar
bronto
They aren't useful at all when you don't use toll roads.
Old Mar 20, 2015 | 01:16 PM
  #63
Petza914's Avatar
Petza914
Originally Posted by PorKen
'PKup'
Unfortunately, it only works in Photoshop land at present.
I hope to have time to work on the deployment mechanism again soon. (Not as easy as I hoped.)
What's cool is, the passenger side door panel has a cutout for the coinholder too. (You can feel it through the carpet.)
The Fischer cup holder is a really nice design. They design a lot of the OEM cup/CD/etc. holders.
I found the cheapest price here.
Did you ever make any progress on this? I have two of these style cupholders and the door panels out of my car so was curious. Thanks.
Old Mar 20, 2015 | 02:29 PM
  #64
oldfrat's Avatar
oldfrat
The Walmart wedge one works much better if you cut the "handle" from a standard cup holder and glue the "basket" in the wedge's cup holder. Here's what I mean by standard cup holder.
Amazon.com: Custom Accessories 91117 Assorted Color Small Cup Holder: Automotive Amazon.com: Custom Accessories 91117 Assorted Color Small Cup Holder: Automotive
Brad
Old Mar 20, 2015 | 04:06 PM
  #65
PorKen's Avatar
PorKen
Inventor
No. I wish. A cupholder solution confounds me. The coin holder spot would be perfect, but I decided it needed a custom mechanism, which is currently beyond me. There's also wasn't an easy way of attaching it to the metal door for stability.
Those nice folding ones don't quite fit right in the hole, although that area is near perfect for a cupholder. Plan-B is to statically mount one of those, hanging down, to a bracket in the coinholder location.
Old Mar 20, 2015 | 04:40 PM
  #66
Petza914's Avatar
Petza914
I'm going to play around with it. I'm thinking if i cutaa couple slots into the bottom of the cup holder assembly, then mount a couple of aluminum L-brackets to the door with a screw through them into a t-nut which is inside the cup holder and cut down so it's just a hair longer than the thickness of the cup holder, I'll be able to tighten the screw and still have it able to slide out in the grooves. I'll need a little strap attached to the cup holder assembly so I can pull it out from the recessed position.
Old Mar 20, 2015 | 04:48 PM
  #67
PorKen's Avatar
PorKen
Inventor
Note the coin holder hole is angled upward...which is another problem of having it slide out. Ideally it would slide out and rotate to horizontal.
