928 Forum 1978-1995
Sponsored by: 928 Specialists
New Crankshafts
Old 02-17-2012, 01:15 PM
  #106
PorKen
Inventor
PorKen's Avatar
Originally Posted by Rob Edwards
Huh- very cool, except if I'm reading the 'how does it work' correctly, it assumes that one has sequential injection, as it blocks injector pulses 1 cylinder at a time (?)
IIRC, the Racelogic box comes with a wiring harness which has individual injector wires. You connect the batch fire signal into the box, but the RL system turns off individual injectors.
(Installation manual)
It'd be cool just for the launch control.
Old 02-17-2012, 01:29 PM
  #107
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
Ah, gotcha. I could REALLY use launch control, spinning wildly is fun for a while but not being able to hook up consistently is tricky. (Most of the problem is lack of behind-the-wheel talent, but the pedal effort with the DD is really light and hard to modulate- even with the assist spring undone completely. Hoping that the new clutch will help. Will see in a couple of weeks.)
Old 02-17-2012, 02:43 PM
  #108
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by Cheburator
Totally agree - when we race our 928s we are all Fangios...
Once again, great work Greg. And on reflection, very, very reasonably priced.
One thing though and you never answered the question asked on this thread by a fellow lister - with the higher rpm and better power outputs which would come along from your new product, is it nigh time you turn your attention to the transaxle? You mention that you want to shift the powerband higher up - sort of BMW ///M engines of old , which is a solution, but ultimately more of a band aid for our cars...
If you can make such great engine products, rise to the challenge and make the 5spd better too
Actually, I am working on a couple of things....
I've been able to see the weaknesses, first hand. Mark Anderson has "provided" me with lots of blown up gearboxes to study.
He's probably the best driver I've ever seen....adapts to anything, with any kind of tires/suspension, at any track....he just drives.
However, he can break a crowbar in a sandbox.
Old 02-17-2012, 02:50 PM
  #109
GregBBRD
Former Sponsor
GregBBRD's Avatar
Originally Posted by dcrasta
No offense intended. I think this is awesome and will be roadmapping in the future (hopefully not too distant) build sheet for a 5.4 (Dream) engine. (Kuhn turbocharger etc..).. I think you have done an excellent job! Congrats
And none taken.
I'm just trying to answer questions.
I did think more about what you were pointing out. The 928 rod is actually wider than a "Chevy" based rod and my "new" rod. That actually means that the rod journal isn't as wide. This does make the counterweight wider, which is what you noticed.
Good catch!
Old 02-17-2012, 03:01 PM
  #110
BC
BC's Avatar
Launch control is available on many newer Aftermarket ECUs. Its almost common practice now and the algorithms are quite stable. It is not rocketscience as it was many years ago. It may not actually affect the longevity of the manual trans however. Its made to get to the very 'enth degree of traction without spinning wheels. Which will net the best take-off, but also probably the most stress on the driveline.
Old 02-17-2012, 04:50 PM
  #111
BIG 928
BIG 928's Avatar
looks like some great engine **** to me!
i have used porsche bearings in my gts race car since 2005, i had a new engine in 2007 and have had 35 podiums since, including 14 wins, 4 of which were at spa which is notoriously hard on engines, so im not blowing my own trumpet but i aint hanging around, im flat out. ( im just tryin to tell people who i am most wont know)
my point being the engines have a lot of failures but the bearings arent made of cheese!
i use porsche oe bearings in my gt2 as well thats 700 plus bhp on a nice day if ive got to catch someone!
sorry to go off thread but i wanted my say, i think keeping the right oil at a certain level is critical as well. to much and it blows it out. to little and your in trouble anyway. maybe i use the englands equivalent of amsoil, but thats another story
Old 02-17-2012, 05:24 PM
  #112
GregBBRD
Former Sponsor
GregBBRD's Avatar
Agreed. The bearings are not made of "cheese". (That's funny, BTW)
It's not like we used to assemble these engines and blow them up, the first day...or even the first week.
As long as you feed the engines with a good supply of high quality oil, keep the detonation at bay, and keep the rpms down, the bearings will last for quite some time.
I figured out that if we watched the oil filters very closely and keep track of what was trapped in the paper, from event to event, engine failures could be kept to a minimum. When the bearings lost their crush, from pounding, it showed up in the filter and we would remove the pan and install a new set of rod bearings.
That being said...it is a known weakness, that has caused many engine failures. If someone (me) decided to build a "better" crankshaft, it would certainly make sense to address as many problems as possible, right?
That's all I'm trying to do. I've always thought that I was on the cutting edge of 928 technology and saw a "need" for improved crankshafts. I made some "major" changes to the "stroker" cranks and decided that I'd make a few "improved" cranks for people that run 5.0 amd 5.4 engines...especially those who want to take advantage of the "newer" camshaft technology available to us and want to "spin" these engines, higher.
Just trying to "improve" our 928's. No other agenda.
Old 02-17-2012, 05:34 PM
  #113
dcrasta
dcrasta's Avatar
Originally Posted by GregBBRD
And none taken.
Good catch!
Hehehe. I do QA and tend to notice wierd things..
Old 02-17-2012, 05:39 PM
  #114
blown 87
Rest in Peace
blown 87's Avatar
That brings up a question, how often should us folks that drive our 928's very hard change our rod bearings?
Old 02-17-2012, 07:08 PM
  #115
GregBBRD
Former Sponsor
GregBBRD's Avatar
Whenever you see them in the oil filter. Bronze colored "chunks" are bad.
I find oil testing to be good, but generally I've found that the pieces come off in such large chunks that the oil testing can completely miss a bearing failure.
An oil filter is the "x-ray pciture" of what is going on, inside the engine.
I cut them open on every car that "sees" a track or gets the crap driven out of it.
Old 02-17-2012, 07:58 PM
  #116
danglerb
danglerb's Avatar
Doing a hard launch with a clutch (or an automatic assuming its set up for it) you release the clutch at a rpm and throttle setting so that the tires initially spin and then quickly "hook". I suspect that is you max torture on the driveline situation.
With launch control the idea is the reverse of ABS, keep the torque just below some percentage of slip, whatever max traction is, hard on the driveline, but not the same level of inertia driven jolt as the tires hooking up. Torque over time might be about the same either way, so I guess it depends on which failure mode you tickle.
BTW at some pretty modest level of power I think breaking manual transmissions is going to lose its charm fast, and until a better solution comes alone there will be a shift to not shifting (automatics).
Whatever happened to the guys in Europe that were working on a more modern automatic?
Old 02-17-2012, 09:42 PM
  #117
BC
BC's Avatar
Automatics will always be... automatics. And they are a compromise - even the new 200k "flappt paddle" gearboxes are not perfect.
Old 02-18-2012, 12:41 AM
  #118
andy-gts
andy-gts's Avatar
automatics are able to better withstand the torque than the 5 speed....per a reliable source
Old 02-18-2012, 03:49 AM
  #119
Imo000
Captain Obvious
Super User
Imo000's Avatar
I was starring in my garage at a left over crank, from a Nissan 3.5 V6 tonight and looked different than the normal V6/8 cranks that I've seen in the past. At a closer look it dawned on me that each connecting rod is seperated by a counterweight and they are not paired up like a normal V6/8 engine.
Greg, I'm sure you've seen this before but what are the benefits of a design like this and would a crank like this could be of any benefit on a 928?
Old 02-18-2012, 12:00 PM
  #120
GlenL
GlenL's Avatar
Then again, is anyone tracking a big power 928 with an automatic? There's a history of breaking the gears on 5spds with strokers at the track, but is there a comparable use of an automatic?
Quick Reply: New Crankshafts
