Redline for an LSD trans???????
#32
i would use the redline 75-90 NS / with half non NS mix
i wouldnt mess with mobil 1. never tried it, but redline seems to be proven under racing conditions.
#33
uggg Greg.. Mobil 1 is also used in the cup cars engines.. and we know how that oil performs in our cars!
the fact that we have less plates puts more responsibility on the fluid. dont know much about mobil 1 gear oil, but i have never had a leak in many transmissions using redline. scots, and all of my 928 racers over the years. no transmission leaks.
Snizinskas (08-26-2020)
#34
Is this the correct oil, that you are all talking about, for 5-speed trannies with LSD?
https://mobiloil.com/en/gear-lubrica...c-gear-lube-ls
thats the stuff! been working great for years after i switched form the redline mix.
#36
Former Vendor
Rod bearings looked like new. Zero cam wear.
While not my favorite oil, hard to argue with this reality.....
#37
So even when the tranny and LSD uses the same oil as in the 928, we should use the Mobil 1 LS gear oil? The gearbox and sync rings will not take harm from the LS ingredients?
It isn't like the LS oil is meant to go in separate "standalone" differentials?
