Transmissions: stock 2.2 vs corvette 6 speed. Laguna Seca comparison
vs
Lots of talk about gear ratios, rear ends, 6speeds vs 5speeds, etc. I think the discussion really becomes about what is strong enough to handle the power, relaiable and has a good feel to get through the gears quickly as a slow shift can drop your ave HP down over 5% (i.e. HP-seconds).
These are races from the SCCA weekend this Oct 2011. however, i was in the AV8SS group 3 and my old ITE group is where the vets are! just my luck, as soon as I start switching groups , all the fun cars start to show back up!
1:38.4 for Bill in a T1 vette is pretty quick...but Bill can DRIVE.....he has Bob's old vette turning 1:53.5's on the bypass at Thunderhill......damm quick...& Bob's old vette is faster than this T1 vette is.....
Its pretty funny, the looks ill get after a nose to tail race with a vet, or someone watching the race when they ask about what my rear end is, and I say, "its a 2.2". Bottomline, its the gear ratios that matter, and in this case the C5 gear box and the S4 are near idential for usable gears and ratios on a track like laguna. 3 gears used. i used two cars with simlar lap times. (im about 1-2 seconds faster, but the HP weight is near the same for both cars.)
his buddie's (bob?) (jim?) video is pretty good too! and it has the telemetry on it too.
http://www.youtube.com/watch?v=3D8O2...ayer_embedded#!
I'm not sure the HP of the T1 car.....I think it must run a stock-ish LS6....maybe just a free flow exhaust + headers and a slight cam change + blueprinting....I'd guess its under 400whp....
His NASA Vette (Bobs) is ST2....I think his racing weight is high 3250lbs so that vette must be 373whp....but I am nearly sure both vettes have 5.7L engines....
Mark, I understand what you're trying to get at now. But I wouldn't consider the transmission in the 928 to be in the same UNIVERSE as the T56 or the newer Tremec in the Corvettes as far as strength is concerned. Not even close. Having had both a T56 in a F-body and a C5, I prefer those to the gearbox in my '86.
Captain Obvious
Super User
Super User
The stock T56 has 2 OD gears (5th and 6th) and is not a close rationgear box by any stretch of the imagination. The 928 does have a 2.2 differential but if you do the calculations thought the gearbox, it's actually not as bad as it sounds.
Correct, T1 cars are basically stock engined with a few goodies in the suspension department and other bits for reliability.
I totally agree, the 928 box is no where the strength of the tremec. the discussion was strictly ratio and HP application.
