928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Bay Fuel Line Replacement ID Size
Old 10-31-2011, 04:33 PM
AaronSweat
AaronSweat's Avatar
Default Engine Bay Fuel Line Replacement ID Size
Hello All,
I found the following regarding the fuel lines. I have my engine out and I want to start with those lines. Does anyone know if the large and small diameter hoses in the engine Bay have the same ID size of 5/16? I have sourced the the pi503 line at my local advance auto, but I want to make sure that is all I need or if I need some larger and some smaller.
Thanks!
Aaron
* Clamps Needed:
o 4ea. 14mm
o 6ea. 15mm
* Engine Bay Hoses:
o Large Diameter: 9"
o Small Diameter: 10"
* Rear Hoses:
o Rear: Large Diameter, 27.5"
o Mid: Large Diameter, 27"
o Front: Small diameter, 9.5"
All the fittings are reusable - replace with EFI hose - 5/16th ID.
Make sure you use SAE30R9 hose.
Old 11-01-2011, 12:47 PM
SteveG
SteveG's Avatar
Roper Tyson has done this work for you and offers a kit complete with instructions on reusing the flanged connections. It is about $100 which might seem high for hoses and clamps, but this kind of leg work is what he saves you; I would be glad to check for you but I disposed of my old hoses, etc. I believe it includes the short piece across the water bridge with threaded connections on either end which is something like $35 by itself.
Old 11-01-2011, 02:21 PM
blown 87
Rest in Peace
blown 87's Avatar
Just get the kit from Roger if you want to just replace the lines, or if you want to go all out get the set from Greg Brown.
Old 11-01-2011, 04:04 PM
ROG100
Basic Sponsor
ROG100's Avatar
Large is 3/8" and small is 5/16" - only use SAE30R9 Fuel Injection hose not fuel hose.
Make sure you use EFI clamps not screw clamps.
The list you mention is for 78/79 CIS cars.
Price for this kit is $76.50 and was compiled by Sharkskin and he also put the writeup together.
Last time I checked the kit was cheaper than buying at NAPA.
Old 11-01-2011, 06:46 PM
AaronSweat
AaronSweat's Avatar
Hey Rog,
I got your email about the kit. I should have mentioned my car is an '81 16V USA model. My guess is you probably already knew that.
Old 11-01-2011, 08:28 PM
GlenL
GlenL's Avatar
I took mine to Pirtek and they rebuilt them with nice crimped collets. They did my oil cooler lines, too.
Skin comes off cat well.
Old 11-01-2011, 08:58 PM
ROG100
Basic Sponsor
ROG100's Avatar
Aaron different kit for your car. I will send you another email.
Old 06-15-2012, 10:22 PM
86'928S MeteorGrey
86'928S MeteorGrey's Avatar
What ID line is used for the fuel rail to injectors on an 84 16V?
Old 06-16-2012, 12:54 AM
SeanR
SeanR's Avatar
Post #6 told you, did you not read it?
Old 06-16-2012, 08:51 AM
Bilal928S4
Bilal928S4's Avatar
Sean,
You meant post # 4?
Old 06-16-2012, 10:38 AM
ROG100
Basic Sponsor
ROG100's Avatar
Bilal, 11.00 pm at night and he is relaxing with a glass of wine and a 6 looks like a 4 8>)
Old 06-16-2012, 03:35 PM
86'928S MeteorGrey
Yes, read post 4.
After post 4 the OP said his was a 16V. Then Roger said different kit.
Also, I'm trying to determine if the fuel rail to injector hose is the 5/16" or the 3/8" ID. I'm assuming it's the 5/16" because it's a very tight fit, but I figure it can't hurt to be sure...
Quick Reply: Engine Bay Fuel Line Replacement ID Size
