928 Forum 1978-1995
Sponsored by: 928 Specialists
The Kraken - A Restoration & Modification Diary
Old 09-07-2013, 10:43 PM
  #166
Courtshark
Courtshark's Avatar
Originally Posted by Hai gebissen
Those look tasty.
Yep. I keep looking at that pic... Will have these on my car some day. Perhaps we can periodically trade CIIIs for these! Once I get the Kinesis wheels ready for track use, that will work just fine, Clark.
Old 09-07-2013, 10:44 PM
  #167
Jadz928
Jadz928's Avatar
What kind of spacers did you double stack to achieve 11mm?
Old 09-07-2013, 10:45 PM
  #168
Courtshark
Courtshark's Avatar
Originally Posted by M. Requin
Great progress! One small word of advice: we haul horses with an F350/V10 and 2 horse gooseneck. Follow your brake controller manufacturer's instructions on calibrating the brake controller, it's really easy, and really pretty necessary. Dang, the Glen in the Fall- that is a very very hard combination to beat! Have fun!
Excellent info, thanks! I'm trying to do as much of this towing "by the book" as I can. Don't want to hurt myself, my car, my truck, or worst if all, someone else. As my brother said yesterday, "towing is a big responsibility." Yep.
Old 09-07-2013, 10:53 PM
  #169
Courtshark
Courtshark's Avatar
A 4mm and a 7mm
The 4s are from Wheel Enhancement. The 7s are... Not. And I'd never recommend double stacking spacers. This was just for test fitting purposes. Eric's looking at some 10mm spacers that should get the job done. eBay units that are hub centric like the W.E. ones.
Old 09-07-2013, 10:56 PM
  #170
Jadz928
Jadz928's Avatar
Right on. Get studded spacers. 11mm is too much for S4 lug studs (not enough lug thread engagement) .
Old 09-07-2013, 10:58 PM
  #171
Courtshark
Courtshark's Avatar
I was surprised how much thread there was left to grab, actually. Seemed like plenty. Up to the bro man I suppose. These are for him.
Old 09-08-2013, 12:57 AM
  #172
Bonton
Bonton's Avatar
Sorry if you've answered this before but what are the rims on the car in your signature icon?
Old 09-08-2013, 07:53 AM
  #173
Hai gebissen
Hai gebissen's Avatar
I like the idea of studded spacers, except the minimum spacer thickness anybody seems to have studded in our bolt pattern is 1 inch (way too thick for this application).
I think I would have to replace my stock studs with longer studs to pass through a 10 mm spacer. Losing 10 mm of lug nut engagement seems like too much (unsafe).
Old 09-08-2013, 08:23 AM
  #174
Courtshark
Courtshark's Avatar
In my avatar? Those are 18" Carrera IIIs. 8s in front, 10s in rear. 57 and 58mm offset, respectively. Easiest 18" wheel to fit to a 928.
Old 09-08-2013, 08:28 AM
  #175
Hai gebissen
Of course, the above depends on 1) the thickness of the wheel being the same on both wheels where the studs pass through, and 2) the factory lug nut shoulders seating properly in the tapers of the 996 wheels, which I am wondering about because apparently 996 models in the 1999-2004 era used lug bolts instead of nuts on studs. Anybody know if the taper is the same as on our 928s?
Old 09-08-2013, 08:31 AM
  #176
Hai gebissen
Mike, you could take one of the Techno wheels and one of your factory lug nuts, and apply some grease to the nut and put it in the hole of the loose wheel (laying flat off the car). This would let you see how the nut shoulder seats in the wheel hole.
Old 09-08-2013, 08:36 AM
  #177
Courtshark
Courtshark's Avatar
Absolutely. But I think the sport technos are not from 99-04. I think they're newer than that. Will check.
Old 09-08-2013, 08:43 AM
  #178
Courtshark
Courtshark's Avatar
They were a one year wheel - 2003. Interesting. Will go check the taper here shortly. When I installed them, my tire iron spun at least 10 times on each lug.
Old 09-08-2013, 08:44 AM
  #179
Hai gebissen
I think they are from 2002-2006. Sorry to hijack your Kraken thread...I should probably start a new thread about this. Or you can with the pic of them on your car...
Old 09-08-2013, 08:46 AM
  #180
Hai gebissen
Do current Porsches use lug bolts, or did they go back to studs with lug nuts?
Quick Reply: The Kraken - A Restoration & Modification Diary
