928 Forum 1978-1995
Sponsored by: 928 Specialists
Noisy Lifters
Old 05-21-2011, 09:09 AM
  #31
the flyin' scotsman
the flyin' scotsman's Avatar
Originally Posted by Lizard931
Malcolm.
When you come down for tires we could sort those pins in a day. Or install cams. :P
Just waiting for someone to eventually come home
Old 05-21-2011, 11:09 AM
  #32
jwillman
jwillman's Avatar
Originally Posted by jpitman2
Are 16V lifters different from 32V units? Cant recall hearing about noisy lifters in a 16V so far. I run mine on 5W40 Delvac, never hear a thing, even after weeks of standing.
jp 83 Euro S AT 53k
After not running my 16v for a few weeks while working AC refresh I had a couple that were quite loud initially and begin to quite down when the engine warms up. I will hopefully get it out for a drive this weekend to see if they will go completely quite as suggested earlier here. Also considering MMO or rislone. Are they equally good?
Old 05-21-2011, 05:57 PM
  #33
Lizard928
Lizard928's Avatar
HAHA understood Malcolm.
Not sure of the exact date yet. The guy I am replacing is having passport and visa issues for being able to come back
Old 05-21-2011, 07:26 PM
  #34
polecat702
Vegas, Baby!
polecat702's Avatar
Put Marvel in the gas tank, Rislone in the crankcase. I've used both for over 50 years. Every car,motorcycle, or our Grand Alaskian, gets one or both. Always!
Old 05-21-2011, 07:49 PM
  #35
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,467 Likes on 1,463 Posts
I'm not much of an "additive" kind of guy, but Swebco makes a product called "Swebco 502". I've used it for years on these vehicles when the lifters get varnished up and keep the checkball from seating inside the lifters. It is an amazing product. I've poured it into a noisy 928 and had it completely cure the issue, in 5 minutes. I used it quite a bit on 944 engines, when I still worked on them.
I'm sure it is mostly a varnish solvent...they suggest changing the oil pretty soon after you use the product, if you have a really dirty engine.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 05-22-2011, 01:03 AM
  #36
the flyin' scotsman
To close off the tread.....the Rislone seems to have done the trick.
I started the car late this aft and was greeted with zero lifter noise and only a faint ticking from the injectors.
Thx Herman and all for the recommendations.
Old 05-22-2011, 10:58 AM
  #37
Herman K
Herman K's Avatar
Default Glad that worked for you...
Bar tender one Scottisch beer please...
Quick Reply: Noisy Lifters
