early dyno results
#436
This is a great thread and I check it every few weeks. Lots of recent activity now and I saw the Utube video of some checks I made to try and figure out the oiling problem. Short story--I haven't quite got there yet. Thanks to Tuomo for posting it. This was done about 10 years ago. I have found out a few more things and some of my initial thoughts were wrong. Maybe I can help steer some to a good solution and save someone from wasting a lot of time.
snip***
snip***
#437
Supercharged
Thank you Dr. Ott.
You've convinced me to re-do my breather system.. I only have a 1/2" breather tube (pipe). I'm going to at least double it (dual 1/2") or go to a single 3/4" or 1" into my Provent.
And to add to your point about blowby, I was at a dyno session once and we stuck a air volume meter on the car and it was pumping out 6cfm at its peak. That's a lot of air!
#439
Now I really think this is what was happening when my low oil level light came on. Because after driving hard (I mean, maxing out the 928 on mountain roads), I could not just stop and sit for a minute and start it back up. I had to sit and wait quite a while before I could get rid of the warning light. Maybe I missed the entire point of Ott's discussion. But I am assuming that I've got a foaming mess in the crankcase. Why else would a perfectly functioning car, with oil level topped up, have a low oil warning light come on after hard driving? And not come on under the same circumstances, when not driving it hard?
But I am probably hijacking the original topic of this thread. So ignore me if that's so.
#441
Under the Lift
#442
I'll have to just go at it again, especially since I have a new oil pump now. It could have been a number of things. But the moment I experienced it, all I could think was that the oil was up in the heads. Which makes no sense once the car is sitting there, unless it's all foamed up. Which I can't imagine would be sustained for very long. I would guess that oils have anti-foaming properties engineered into them.
#443
Supercharged
1/2" + 3/4" cross section area = 0.64 sqin. If I tie them into a 1" pipe, the 1" cross section area is 0.78 sqin which is great than 0.64. So I don't think there will be much if any benefit at that point of going any larger.
Pics to help illustrate.
![](https://lh6.googleusercontent.com/_Q-VMuv9awdo/TVh8yEiB10I/AAAAAAAAF1A/1lk1I73f45Q/s800/andrewBreatehr%20%2811%29.jpg)
![](https://lh6.googleusercontent.com/_Q-VMuv9awdo/TVh81TdYQWI/AAAAAAAAF1Q/FTtSCsKE_H4/s800/andrewBreatehr%20%2812%29.jpg)
#444
Thank you Dr. Ott.
If I'm a Dr., how come I'm so poor and don't get to play with young women? Heh, heh. Maybe because I spend all my money on toys.
Thanks for the firm information on the blowby volume. That fits fairly close to what I remember reading. Also, you are experiencing the challenge of providing enough breather area to get rid of that blowby without raising the crankcase pressure enough to blow out the oil. What do you have under that plate covering the oil filler opening? Is there anything to try and separate the oil from the gases? Just wondering because a separator there will help out whatever you have downstream to eliminate the oil in the blowby.
#445
Former Sponsor
Louie:
Thanks for joining into our discussion. I've made some notes below, in your post and highlighted them with blue.
Louis:
In the ten years that has passed since you did this video of the valve cover, an entire boatload of 928 engines have failed at the track, with windage trays, pan scrapers, lowered sumps, trick this and that, even with dry sumps. They've failed with stock engines..and they apparently fail with stroker engines (I've not lost a stroker engine from this problem...to date.) I've had rods break, with the bearing perfect. I've had dry sump tanks get sucked dry and had engines "stick"...but I've avoided the 2/6 rod bearing issue. I agree that if the engine rpms are kept very low, one might avoid the 2/6 rod bearing problem....if they have are very careful and routinely check/replace the rod bearings on a regular basis. (We actually have a full size engine drawing that we have marked off grids betting where Kibort's rod will come through, when it finally decides to leave.)
I'm thinking that perhaps what we have found here, might be something "new" that hasn't been seen, to date. I'm thinking that if we could figure this out and somehow "correct" this defect, there might actually be some "extra" engines laying around in 10 more years. At the rate they have been "consumed" in the past 10 years, therre will not be many left, 10 more years out. Try and look at this with an "open" mind, as "new" information...not just the same old unresolved problem.
I'm a big fan of Smokey Yunick and you'll find a lot of answers applicable to the 928 in his books. One of my favorites is "Power Secrets". I'll list a few things as I can remember them in no particular order. I've always found it very difficult to separate "fact" from "filler" when reading Yunick's books. Sometimes things get so ridculous, I have to just laugh and put his books down.
1. The 928 engine lubrication system is horribly designed for any high performance use. That it can have any reasonable high performance life is due to ingenuity, patches to cover impossible design flaws, and luck. Or, you can do like the very successful high time racer we know and limit the RPM especially in corners. It's not really the Amsoil. It's the driver. Perhaps some of each. If Amsoil is resistant to foaming and flows better, it could make a difference.
2. Using the holy cam cover we checked to see just exactly how much oil was being pumped up to the right side cyl head at high RPM. We did this at the old SIR track (near Auburn, WA) during a drag event. Several current 928 owners were there watching. Adam Birnbaum, Tom Middleton, and a few others. Revving the engine to over 6000 to rev limit cutoff showed plain non-aerated, oil splashing around and a small rivlet running rapidly down each drainback hole. It didn't even take 1/4th of the drain back area to easily handle the oil. The amount of oil didn't change above about 2500 rpm. The 928 oil pressure regulator keeps pressure to about 100 psi from around 2500 on up depending on oil temp and viscosity. Oil system oil fed to the head is not too much for the drain back holes and it doesn't change in volume with RPM. There is no point to limit the oil feed to the cams. Don't bother. So, considering this, why did Porsche bother trying to limit the returning oil to the heads, in the 944S2? I have no data about this engine that you ran (size, age, builder, etc.) I see that this engine apparently suffered rod bearing failure on the same day as you were doing this test...is it possible that the bearings were already damaged and this had some effect on the volume of oil in the heads?
3. The normal oil level in the sump is way too close to the crank. It is less than an inch and with a stroker motor less than that. Do not overfill the sump. An over full sump can cause oil to hit the crank even with no vehicle motion. It's a tornado in there. Smokey Yuniks advice was to keep the oil as far away from the crank as physically possible and should be more than 2 inches with 4 inches being better. This is impossible with the 928 low mounted engine and flat sump. The aluminum spacer between the block and sump helps, but is only a band aid. Any sloshing of the oil will cause it to be hit by the rotating assembly and 1) turn to foam, 2) be caught up in the vortex around the crank. The whirling crank is like a centrifugal blower. Low pressure in the center and higher pressure on the outside. When the rods hit the oil the oil goes toward the low pressure center usually near the ends and gets flung to the outside where it hits more oil and the cycle repeats. It is a rotating helix of oil foam. The whirling crank can hold more than a gallon or so of oil in a molasses colored cloud. This can cost maybe 30 hp, heats the oil, and once started, is hard to stop while at high RPM. Crank scrapers are supposed to help control this. A dry sump is one answer, but not usually achievable on a street driven car due to no room for the tank and no available drive for the pumps. Reasonable assumptions....pretty standard thinking.
4. I used to think that the frothy oil seen on the uTube video through the holey cam cover window was all oil whipped by the crank and forced up through the drain back holes by crankcase pressure and vented out the cam cover vents. Kevin Johnson had a theory that a lot of the oil foam was coming through the oil system and expanding as it came out the cam bearings. I think he is largely correct except a lot of the foam does get blown up the drainback holes too.
5. Accusump.. It's a good thing and probably does save engines in some instances of oil pressure loss. However, consider this. By the time you have uncovered the oil pump pickup you have foamed your oil in a 928. The accusump may have saved your engine, but now it will be recharged with foamy oil. If the Accusump is mounted vertically with the inlet/outlet at the bottom, and it isn't called upon to discharge for a while, the air in the oil may have separated and you could get a discharge of clean oil. Or you could get a discharge burp of air.
6. Stroker motors with the stock intake manifold are breathing limited and the hp peak is around 5000 RPM, maybe less depending on the cam and valve size. It's fairly safe that the oil won't get to a condition to foam at 5000 or below. Change the intake to a ITB where peak power is 6500 or more and the longer stroke motor will be more likely to foam the oil than a short stroke 5L. Logical progression of thought. Keep in mind that a "boat load" of non-stroked engines have failed from oil issues.
7. Smokey is adamant about providing sufficient crankcase breathing. IIRC, the 6.5L size motors should have a breather tube of at least 1.5" and the 5.0L will be ok with 1". It is really hard to get a 1.5" breather on a 928 anywhere. I use two 3/4" breather tubes to my air/oil separator and a 1" from that to the atmophere. I'm fairly confident I read that a 5.0L motor will normally make about 5 cfm blowby and the 6.5L about 7 cfm blowby. If not vented from the lower part of the crankcase, where does it go? Does it seem too much to conclude that the blowby will simply go up the cyl head oil drainback holes and vent out through the cam cover vents? If you have foamy oil, that brown froth like whipping cream will go right along with it. When the crankcase is properly vented, the foamy oil won't go up the oil drainback holes. It still foams, but doesn't blow up the drainback holes on either side. The key to understanding that the too much oil in the cyl head problem is crankcase pressure, and not so much the rotation of the crank pumping oil up there. It is a factor, but not the only thing. Stock, the 928 32v motors have horrible, pathetic, inadequate, crankcase breathing. Throw it all away. If you want to stay green, (and there is nothing wrong with that) put on an adequate (big as you can fit) crankcase breather, run the vent through a good air/oil separator such as the ProVent, plumb the outlet back to the air intake - not the intake manifold below the throttle. The air/oil separator oil drain can be "T"ed into the oil dipstick tube. It'll work. Otherwise, vent the separator outlet down vertically under the car with the end of the tube cut back at a 45 deg angle. That will provide some small vacuum as you are driving. The location of the crankcase breather is a problem, too. My dyno testing shows that there is a "solid" slug of oil up in the crankcase breather area, above 4,000 rpms...being whipped up by the crank. Dealing with this oil and getting the crankcase to breathe, at the same time, is a challenge.
8. Cam cover vents. I've always wondered why 928 folks seem to think the cam cover vents need to be used as an outlet vent. The answer is probably obvious if you consider that the crankcase has no reasonable vent and the blowby has to go somewhere. Might as well use the cam cover vents so the blowby can carry a bunch of oil along with it. Not a good plan. Nothing inside the cam cover generates any gases that have to be vented save a bit of exhaust gas escaping past the exhaust valve stem seals and that isn't much if any. The cam cover vents should admit some fresh air. I like to plumb a line from filtered air to one cam cover vent on each side. Use the shield on the inside of the vent to keep oil from splashing into the tube. One cam cover vent makes a good place to have an oil filler if you can't use the original such as with ITB intake or Andy Keel type supercharger intake. You have to enlarge the hole and weld on a small can and have a cover. It works fine to just use an O ring seal on a push on cover. Remember, with a properly vented crankcase there is no pressure inside to blow off a cap, or the oil dipstick. Porsche clearly is using the valve cover "vents" as breathers. The crankcase "vent" obviously is awful. The crankcase is connected to the heads. Seems like a logical thing to vent the entire engine from the valve covers. It has worked for years, venting from the highest spot.
9. Speaking of crankcase pressure... Next time a 928 is on a dyno of any kind. Take off the oil filler cap and put your hand a few inches from the opening. Do a short run and you'll be amazed at volume and velocity of the blowby coming out. Where does that normally go? Maybe up the oil drain passages? Kind of a scary thing to do.
In my tests, I did measure the amount of air coming out of the crankcase vent and the valve cover vents....with my calibrated hand...just like you suggest. The crankcase vent always had significantly more pressure than the valve cover vents. If I look at this situation, from a pure logical point of view, since all of the breathers are interconnected into the same "pressure vessel", it would seem that all the vents should have the same amount of pressure. I fail to see how you can have a "lcoal" vent, in the same pressure vessel, that has more pressure than a remote vent. Pressure should be pressure, in the same interconnected container. I submit that this is the result of the head vents being restricted/plugged by the returning oil from the head oiling.
10. The vented oil filler cap I made works quite well at keeping the crankcase pressure down so no oil is ingested into the intake. If the breather system is otherwise stock there will be a slight vacuum pulled in the crankcase at idle and cruise throttle. That means air will be drawn in through that breather tube. I connect it to the smog pump air filter that is right in front of the oil filler. I don't need the smog pump filter because my smog pumps seem to fall off shortly after I get the car.![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
11. I don't buy the idea that so much oil gets blown up into the heads that the oil pump runs out of oil. Look at the utube video and you see quite a lot of foamy oil, but it is far from filling the head. The video was taken looking at the exhaust cam so is at the bottom of the cam cover. Even so, it's foam not solid oil. How much beer do you get when drinking foam? Whipped to a froth, there probably isn't more than a cup or two of actual oil. True, it represents some excess oil and it shouldn't be any oil. Fix the crankcase pressure problem and you'll have less, maybe none, foamy oil up there. And for goodness sake don't vent out the cam cover vents. Let fresh air in there. It flushes out combustion byproducts![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
One more time... Vent the crankcase and you don't blow anything out the cam cover vents. So, in the video, I see the oil over the top of the camshaft, only. Several times, it appears that the camshaft is completely covered with oil. I don't have another perspective, from the video that shows me the amount of oil that is below this level. I assume that the entire area, below, is completely full.
12. That still doesn't eliminate the foamy oil. It only keeps it from being blown out the vents. I think the oil pressure loss we see in a hard corner come mostly from having too much foam relative to solid oil. I think the 2/6 rod bearing failures come from having too much foam in the oil, not necessarily no oil. In my dyno test, I got no "foam" out of either the crankcase, nor the valve covers...it was pretty much just pure solid oil. I do see the "foam" in your oil...perhaps my oil foams less than yours?
13. That gets back to how to keep from having sloshing oil so close to the crank creating all this foam. Crappy design. Use what band aids you can. I have an idea I want to try, but have no time right now. It involves electric pumps and G switches. You can figure it out. I think it may be the next best thing to a dry sump. So, I have done dry sumps. As I mentioned previously in this thread, the dry sumped engine looses oil volume from the tank, at higher rpms. I'm thinking that this is the result of the oil "packing" into the cylinder heads.
14. Where to vent the crankcase? Up top somewhere. I doubt it matters much. Do something to keep the velocity of exiting the blowby gases as low as possible and that means a big area thing. I use the normal big hole up front where the oil filler is. I make a metal box that fits down inside and is angled on one side to conform to the shape of the hole. The box has louvers, or holes angled so slung oil would not go through as readily as if it was a straight hole. Plenty of holes/louvers. Think keep velocity low. I leave the bottom 1.5" of the box empty to give oil a chance to drain out. The top half of the box has some folded screen or loose copper Brillo pad. The top of the box has a cover bolted to the block where the oil filler fastens. Then a big hole leading to a vent tube, or another box with some maze type passages with right angles then leading out to a big (1"+) outlet tube. You want to make the oil laden blowby take sharp turns so any liquid can't follow the gases out. Liquid will collect and run back inside. That is if the box is big enough to keep velocity down. The outlet of this pre-air/oil separator needs to go to another air/oil separator like a ProVent or a similar home made device.
15. The Utube video was made at Spokane 10 or more years back. Spokane is ideal because of the killer left hand turn at the end of the mile long straight. Worse than at Thunderhill because it is longer and faster. It was run CCW. I had no audio as that would have helped a lot to determine where we were on the track. Mainly, you can see the foam begin to clear up about as soon as we got back to turn 1 and 2. I think lap times would be around 2:30. I wasn't driving. I had an instructor who could push the car harder than I could (better driver) and I was holding the video recorder. He turned the engine as fast as possible. The entire straight it was up to 6600 in 3rd, shift up to 4th then 6600 shift, etc. You shift to 5th a bit before braking at the slight rt hand turn 1. The long turn 2 corner was at near 6000 probably in 3rd. I told him to rev as high as possible so I could get a good showing of what happens. Note that the foamy oil happens whether in a right or left turn, but the left turn is worse. Shortly thereafter, (next track session) I realized my rod bearings were shot but didn't destroy the motor.
16. Anyone want to borrow the holey cam cover for their own testing? All I need is shipping. Marc Thomas lent me the cover to cut up for testing. I think one of the lexan covers has come loose, but I think it is still there.
Guess that's about it. Back to the airplane factory.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#446
Supercharged
Hi Andrew,
I've got a couple of baffle plates under the plate. Tony Harkin built it for me. Here's a sketch to illustrate.
![](https://lh4.googleusercontent.com/_Q-VMuv9awdo/TVh9EdgSIAI/AAAAAAAAF1c/Y8Mcene8jIE/s800/oilssepAO3%5B1%5D.jpg)
#448
Under the Lift
This warning light came on as I was driving hard, I believe. I can't remember, but I would swear it was a low oil level warning. Which may very well be just a low oil pressure warning. But when you pull the pan, there is an oil level sensor. I'm pretty sure it was low oil level. In fact, I remember getting out and looking at the dipstick with no oil on it. Yet the car was topped up before I went out.
The only time I've seen the low level warning was when I went to start the car after I parked facing up a very steep hill. The level sensor is in the front of the pan, and I knew I had plenty of oil. Now that I think about it, I recall that the oil level sender is not read once the engine is running, so I'm not sure what to make out of your seeing it while driving along. We (Jim Morton, Dennis Kao and I) did some testing and found that the sensor trips at anything below 5 qts in the sump on level ground, which is 3-4 qts low in a resting motor. It would be quite common to see less than 5 qts in the sump under common running conditions, so the sensor is ignored when the engine is running.
#449
What weight oil were you using at the time?
