928 Forum 1978-1995
Sponsored by: 928 Specialists
tail light sockets.
Old Nov 17, 2010 | 07:48 PM
smyth1's Avatar
smyth1
Default tail light sockets.
anyone know of any aftermarket ones available or something that will work in their place?thanks
Old Nov 17, 2010 | 07:55 PM
Alan's Avatar
Alan
Electron Wrangler
It depends what year...
Old Nov 17, 2010 | 08:16 PM
smyth1's Avatar
smyth1
Old Nov 17, 2010 | 08:43 PM
SeanR's Avatar
SeanR
Did they repossess the taillights too?
Old Nov 17, 2010 | 09:20 PM
smyth1's Avatar
smyth1
no they are rotted out wiseass!
Old Nov 17, 2010 | 09:24 PM
Dictys's Avatar
Dictys
I drilled out the rotten plates in the bottom of the connectors and then fixed copper spring connectors like you find in a normal bulb holder, works like a charm now, no more tail light out messages.
Old Nov 17, 2010 | 09:29 PM
karl ruiter's Avatar
karl ruiter
I don't know the details but think they are avialable from NAPA or something. Try a search.
Old Nov 17, 2010 | 09:51 PM
CJs 928's Avatar
CJs 928
This is the link I think Karl is refering to:
https://rennlist.com/forums/928-foru...grade-mod.html
I haven't tried it though.
I just soldered a wire to the bulb and cushioned with foam (to add spring and allow it to catch tightly) and now good to go.
smyth1's Avatar
smyth1
tried the napa website and called the store and they have no listing.going to try and make some universal ones fit.the ones that have the push in prongs may work with a little fab work.
Old Nov 17, 2010 | 09:52 PM
CJs 928's Avatar
CJs 928
Smyth1, look right above your post-I was typing as you posted your NAPA defeat.
Old Nov 17, 2010 | 09:56 PM
SeanR's Avatar
SeanR
Wiseass says to check out a Nissan Odyssey tail light harness.
Old Nov 17, 2010 | 10:22 PM
jeff spahn's Avatar
jeff spahn
I heard there are some Subraru fits as well
Old Nov 17, 2010 | 10:24 PM
SeanR's Avatar
SeanR
I've got some of the odessy ones here, they trim out to fit in our housings after a bit of work. They also come in pairs, so you have to rewire them individually, or modify the 928 housing to accept them both.
Old Nov 17, 2010 | 10:26 PM
karl ruiter
My S4 has had some of them replaced with something different than stock or what was shown in the post. Something generic, I think.
Old Nov 17, 2010 | 10:34 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
+928 They work. You have to cut them a little to make them fit but its not hard w/ a razor. You will also need to make some gaskets but these are great upgrades because they use the dual filament bulbs. You can wire them in a way that will brighten your tail lights vs the stock ones. It's been awhile since I've done it but once you look at them next to the old ones it will be obvious.
