Overheating after WP replacement... Place your bets...
#226
So given this,we built a quick test stand and install all the pumps on it now and run them for at least an hour at 7400 rpm.This allows the bearings to seat and ride through any "rough spot" and lubricates the seal and allows us to analyze the pump and drive,check the seal and gasket surface for leaks and should eliminate any start up or early run issues. Here is a quick vid of Stephan's pump before last week.http://www.youtube.com/watch?v=GwEn5VGhzsI
Ed
#228
Break-in period officially ended Wednesday evening... Straightened the curves out of several miles of the back country roads nearby and 6600 RPM never sounded so good!
We're back in business and loving it! Temporary daily driver... Can't help myself (or wipe this silly grin off my face!)...
#229
I have always found it a very good idea to over test all production units when a design is new or recently modified. Seems like to there are always possible variations that can lead to failures, and you just cannot anticipate them all.
#230
That is funny. you guys are really sick! probably a little easier to just install the engine and run it.
what is the ratio of our engines and water pump (drive pulley vs water pump)? interesting that 3hp runs the pump to 7000rpm no problem in a flash. the only other thing I would do, would be to put white marks on the pulley or motor, and see how fast it runs under load. with the RPM of the electric motor known, you could then figure out the force required by the waterpump. yes, its a 3400rpm motor, but synchronous speed is 3600rpm. the induction motors slip, naturally and follow a torque/speed curve. how far it slips, tells you (approx) what torque is needed. i mean , as long as you got that set up running, why not determine a few things.
Nice job! I guess the water pump works.
#231
Very interesting thread. I have one of Ed's innovative design WPs on order and am really glad that he's now performing a bench test to double-check Laso's parts quality too. I almost ordered a new Porsche WP but I'm not sure I trust their stuff any more. Ed can provide quality oversight that low-bid manufacturers/suppliers may not. The peace of mind that comes with his run-in test is worth extra money.
H2
H2
#232
As I get ready to do a timing belt replacement, I am reading what I can on the subject. I am interested in Ed's pump. Can we get a link to his water pump here? I like the idea of one less possible problem in the timing belt train.
And Ed, you might incorporate go no-go guages in your quality control. You may already. That impeller distance would have been caught without any measuring. Also, without knowing the geometry of the bearing setup, you might take another step in pressing bearings in order to eliminate any preloading they have against each other. My guess is that is where the 0.005 thou came from. Bearings running against each other. You may press them from the outer race, but then the inner races could be in a loaded condition. It may not be an issue, either.
Link, please! I'd like to get one of these pumps.
#233
More recent thread: New Product from 928sRus "Engine Guardian" Water Pump
Older thread: ***WATER PUMP PROBLEM SOLVED- (PICS ADDED)***
FWIW, mine has been up and running since July. Really glad I did it.
#235
#236
All my customers deal with me by email at roger@928srus.com.
Better and quicker to buy directly from ED.
