Track Day.... driveshaft slip out?
#31
If you failed the input/5th gear, you will need a TT rebuild or swap anyway, so changing up to a newer box isn't a big deal. I don't remember if the rear crossmember is different, but that also comes out with the trans.
Finding a newer box is not always easy...esp if it has LSD.
If you repair yours, send it to Greg Brown...
#32
If you can see metal through the TT holes...then it appears the TT is broken...which is good and bad...the good news is a rebuilt TT is only $400.....so its fairly cheap.....the downside is its a bit of a PITA to do.....
MK
Sounds like you owe me a beer!!
MK
#33
not so fast grasshoppa. metal will come through the hole for the break, no mater where it is. i still bet it is on 5th, but I hope it isnt! 5th is the weak link, due to its design. it should have been a design like the short shaft up front and a beefy coupler (or not so beefy so it can break before the shafts)
#34
And not just one, PARTY!!
#37
You know, we'll have to ask Marc at DEVEK.
They built the car.
Yes '79 (no sunroof).
S4 body ends
on an '87 chassis. (bigger brakes, padgid orange)
Its been a blast!
First time any repairs. period.
#38
How do I get a hold of him?
#43
Under the Lift
#44
#45
