928partseast inventory
Here is a good portion of my inventory very general. Please email at 928partseast@gmail.com for more info.
Thanks,
James
Auto Trannys $600 Each (10 in stock)
Diffs $300 (6 in stock) LSD Diffs $600 (3 in stock)
Motor Blocks $500 (5 in stock)
Complete Motors $1250 (2 in stock)
Cylinder Heads $300 (22 in stock)
ABS Pumps $250 (13 in stock)
Cranks $225 (13 in stock)
Intake Manifolds $150 (7 in stock)
Exhaust Manifolds $125ea (20 in stock)
Throttle Bodies $75 (10 in stock)
Piston Sets $300 (9 in stock)
Pulleys/ Balancers $50 Ea (50+ in stock)
Torque Tubes $150 (10 in stock)
Belt Driven Gears $50 (20+ in stock)
A\c Compressor $125 (12 in stock)
Starters $100 (18 in stock)
Power Steering Pumps $100 (10 in stock)
Alternators $100 (14 in stock)
a\c Fans $75 (15 in stock)
Climate Control BLOWER FAN $75 (11 in stock)
Belt Driven Fans $125 (9 in stock)
Front Bumper Covers $150 (10 in stock)
Aluminum Bumper $125 (8 in stock)
Fenders $150 (16 in stock)
Hoods $200 (4 in stock)
Rear Bumper Covers $100 (20 in stock)
Timing Belt Covers $35 (100+ in stock)
Brake Calipers BREMBO $125 ea
Brake Calipers OTHER $25 ea
Headlight Motors $50 (10 in stock)
Power Steering Res. $25 (10+ in stock)
FUEL TANKS $200 (7 in stock)
Wiper Motors $50 (20+ in stock)
Heater Cores $100 (10+ in stock)
Cruise Solenoids $75 (10 in stock)
FENDER LINERS $50 (10+ in stock)
Rear Interior Panels $125 (22+ in stock)
Sideview Mirrors $50 (10 in stock)
Washer Res. Tank $35 (25+ in stock)
Side Markers $35 (25+ in stock)
WIndow Motors $40 (20+ in stock)
Tranny Coolers $50 (10 in stock)
Fog / Driving Lights $40 (20+ in stock)
Fuel Tank Straps $100 (5 in stock)
Fuel Pumps BLUE BOSCH $100 (2 in stock)
Ext. Temp Sensor $50 (3 in stock)
Air Flow Meter $100 (4 in stock)
Oil Pans $100 (7 in stock)
Engine Intake Tubes $50 (7 in stock)
INTERIOR
Sunroof Motors $50 (5 in stock)
Sunroof Trans $30 (5 in stock)
Horns $25 (15+ in stock)
Cruise Control/ Trun Signal Assy. $55 (8 in stock)
Pod Switches $15 (100+ in stock)
OEM JACK $40 (8 in stock)
A\C Heads $100 (5 in stock)
Leather Dash VENTS $40 (5+ in stock)
Rear A\C Unit $100 (4 in stock)
Headliner $125 (7 in stock)
Rear Consoles $100 (12 in stock)
Arm Rests $75 (12 in stock)
Visors $25 (50+ in stock)
Glove Box Doors $40 (6 in stock)
Under Trays $50 (10+ in stock)
Dash CORES $50 (10+ in stock)
Door Upper Trims $40 (15+ in stock)
Rear Seat Bolsters $30 (20+ in stock)
Seat Belts $25 (100+ in stock)
Tool Shelf $40 (10+ in stock)
Front Console CORES $50 (2 in stock)
Carpet Sets $150 (3 in stock)
Steering Wheels $75 (7 in stock)
POD CORES $50 (7 in stock)
Thanks,
James
INTERIOR
Man of many SIGs
James,
I'm not trying to be critical but you need to describe these items a little better. Saying you have an LSD for $600 doesn't tell me which ones you are selling. The same goes for the engines, cylinder heads, intake manifolds, engine blocks etc.
Just a suggestion. Good luck.
Interesting, it had listed him as a sponsor before.
But even though he had dodo birds inventory let's not associate him with dodo.
Let's give him the benifit of the doubt to start.
But as always a good description, photos and the ability to throw away the junk!
James, I am interested in early transmissions. The case is the main thing I need, blown gears etc don't matter. I want to pay as little as possible as they will be used for R&D
As mentioned, you should always post business-related stuff under your Rennlist business name - not your personal account.
That said, you might want to become familiar with the Rennlist Charter, especially Article 7:
https://rennlist.com/charter.htm
Good luck!
Good luck!
Under the Lift
In not so many words he said it was a "general" list. I didn't remember right away that these came from Mason's, umm, yard. That does make them "generally" suspect as to condition too, but perhaps that is reflected in the prices. I need a PS pump, but I'd like one that is in good working condition.
I am familiar with the rules thank you.
Also, Mason has nothing to do with this business what so ever. He transitioned his inventory and warehouse/shop to me and is far away. This is all me and me alone so order and you shall be happy.
Thanks,
928partseast
Thanks,
928partseast
Add your real first name to your sig as well as 928s you own and a link to your business website.
That way, folks know they're dealing with a 'real' person and 928 owner.
"Any further 928ww parts related warranty claims will be handled by the new owner."
Best of luck!
