928 Forum 1978-1995
Sponsored by: 928 Specialists
Cam timing inconsistant with each revolution
Old 07-26-2010 | 03:43 PM
  #136
76FJ55's Avatar
76FJ55
Originally Posted by Vilhuer
Probably doesn't make much difference as numbers are estimates anyway but that engine is very early prototype which used carburetor and didn't yet have washer tensioner setup. Notice how there appears to be plate where tensioner roller is mounted and bolts to secure it to block and adjust tension.
I knew it was a very early motor I only used it as it was a convinient head on view from which I could get a quick estimate of the belt run lengths. I had to guesson the loocation and diameter of the crank pulley as well as the harmonic ballancer ans accessary pulleys had it. So is it exact? No, but close enough to give a general idea of the configuration.
when I installed my tensioner I used a short bolt with a little sealant on the threads and it seems to have worked well. I wasn't comfortable with the set screw plug either.
Old 07-26-2010 | 03:56 PM
  #137
PorKen's Avatar
PorKen
Inventor
Originally Posted by jcorenman
Ken,
Let me explain more fully what I tried to say before: You're asking us to accept the tensioner design on faith. We're asked to do that with respect to religion. But this is not religion, it is engineering, and accepting a new design on "faith" is not appropriate. I know little about religion, but I am quite comfortable discussing engineering, having spent my life doing it (I am not a young guy).
Sound engineering designs are based on analysis and testing. And there are some legitimate questions here: the Audi tensioner is well-proven, but it is being used in a different application: A different geometry which may or may not be significant, with a larger belt driving higher loads which may or may not be significant. That makes it a "new design", different from the factory tensioner and different than the original Audi application.
There are generally two ways to prove out a new design: careful analysis, and thorough testing. Generally both are done. I assume the spec's for the Audi tensioner are not available, and we cannot duplicate the original environment (which I believe is an Audi 2.7L 4-cam V6). So the best we can do with a design analysis is to compare loads, resonant frequencies etc with the original application: If those match then we can "inherit" the confidence in the original design.
That is not simple (measuring dynamic tension of a moving belt is not trivial) and I assume you haven't done it. Which is fine, because a design can also be proved out with testing. Which is what we are all doing now.
I have reasonable confidence in the design, and we have your tensioners in both of our cars. But I do consider it experimental, and I keep a careful eye on them. I am happy to do that because we work on our own cars, and if things start to look unhappy then I am out a bit of labor. And if things come apart and wreck the valves, well it was my choice. Personally I think there is very little chance of that, but I am not 100% certain that the Audi tensioner won't suffer premature failure because of the change in its application.
Guys with professional shops have a different basis for their choices. If a part fails, they own that failure and need to make it right. That's quite different than you and I.
So in GB's position I would be asking for exactly what he has asked for: the data to support a design analysis. It's not available, and probably can't be available with the means available to this community. And there are differences: The Audi tensioner was designed for a smaller motor, the belt tension is lower than Porsche intended, and the damping is handled differently (and almost certainly better). Those things may be just fine but the only way that we know for sure is by thorough testing. When hundreds of tensioners have gone six years and 60,000 miles then the confidence level will be very high. But we're not there yet.
My suggestion is that it is not reasonable to expect professional shops to be part of the testing program, and it is not reasonable to criticize them for declining to do so-- or for asking for the data that they need to get comfortable with a design in lieu of extensive testing.
Cheers, Jim
Jim,
My question was rhetorical (and snippy ), but thank you for the larger context.
It is about faith. When you pull the pin and turn over the engine for the first time, you are probably holding your breath. I still do. But I did this with the stock tensioner system too. From that point on, though, in contrast to the stock system, there is a sense of peace, knowing the belt is controlled automatically.
The PKsn'r was an organic development, seeded by a desire to counter the accepted failings of the stock tensioner system. I did not have the facilities (or faculties) to create a tensioner from scratch, so I looked for a proven system that would fit. I looked at many, many tensioners, and feel fortunate in finding the Audi 2.8 30 valve tensioner, in that it was proven, with no issues that I could discover since it's inception, and fit. It has the same size tensioner pulley as stock, and it even fit through the old hole in center cover! I tested it on my engines, and was pleased to find that the tension was acceptable, too.
I see the Audi system as being under-stressed used on a 928 engine. The 2.8 spins faster, and more quickly than the portly V8. The belt on the 2.8 is heavier, wider and thicker. (The only belt length that the tensioner sees is the distance from the cam gear to the crank gear, total length is not a factor.) The tensioner and guide pulleys are set higher in order to save space. The original 2.8 belt change interval was >100K miles, and the components reflect this. The pulley bearing is massive. The bushings are steel. The system is very compact. Anyone who's compared the Audi to the stock parts can't help but chuckle at how cute the stock parts are.
It is obvious to any observer of a running engine with the covers off that the PKsn'r is a superior belt management system, and this talk of belt tension is a bit like trying to put the proverbial cherry back in the box, and a distraction. There is no specification from Audi for the tension. The static tension between the 1-4 gear, and the crank gear is irrelavent as soon as the engine begins turning. GB has admitted in a previous 'discussion' that he trashed one of Mark Anderson's race engines at startup when the belt skipped teeth. If the stock system will allow enough slack belt to form to skip teeth, even when the esteemed GB has set the static tension, how much faith should regular folks put in a tension warning light that has a 3-minute delay when the engine is started? If it can happen in sunny SoCal, what about when the engine is started in northern Canada?
GB introduced this notion that the tension is less with a PKsn'r by spinning the engine by hand, and pushing on the tensioner piston. No measurement after running the engine to allow the hydraulic action to work. (A simple Kempf tool check that anyone can do will show the tension is fine.) Now, he's pushing this cam timing notion, which came about, again, from improper procedure on the part of the original poster. From the start, for whatever reason, GB has disliked the PKsn'r, and has jumped on any opportunity to cast aspersion to it. (BTW: I would like to believe that MA did not conspire to help GB in his quixotian quest {post #41}, and that he was genuinely interested in selling them when he emailed me about doing so.)
The PKsn'r was not made or 'marketed' for repair shops. It was made for the home mechanic who doesn't want to worry about retensioning the belt, or spinning the engine to redline. (15K miles? It's a Porsche, not a Ferrari!)
Gruß,
Ken
Old 07-26-2010 | 03:57 PM
  #138
GregBBRD's Avatar
GregBBRD
Former Vendor
Ken,
Cheers, Jim
Jim:
I've been trying to get this point across for almost three years and all I've ever gotten back is wise *** condenscending defensive bull****, making fun of me and my shop.
Hopefully you do better....although I'm not sure I even care anymore.
Old 07-26-2010 | 04:20 PM
  #139
PorKen's Avatar
PorKen
Inventor
And yet PKsn'rs keep going, and going...
(since 2006)
Old 07-26-2010 | 05:24 PM
  #140
PorKen's Avatar
PorKen
Inventor
Originally Posted by blown 87
Direct question Ken, are you going to stand behind them if they start to fail and pay for damages or is it going to me left up to the guy that put them in?
If the tensioner bracket breaks, I will replace the bracket with a new one.
SOP on aftermarket or 'race' parts.
Old 07-26-2010 | 05:35 PM
  #141
GregBBRD's Avatar
GregBBRD
Former Vendor
Yeah. I don't really feel like trusting one of my engines to faith. I'd like to have something just a bit more reliable and trustworthy...like a stock tensioner, that has proven itself for 30 years and millions of miles on stock engines. Imagine the mechanics at Porsche "holding their breath" that the stock belt tensioner would work on every engine. BTW...I missed this instruction in your installation manual...."Hold your breath...I still do!"
We all know what you "see", by now. All I've ever asked for is some data to back up what you "see". I admire the simplicity of the Audi design...when engineered to work on an Audi. When it is "pulled" off a shelf and applied to a different application, with different distances from the sprockets, different fulcrum and different leverage...I kinda need some engineering data...still.
You keep twisting this all around....over an over again! This was always an example of how crappy an aftermarket belt was and how far they stretched. This had nothing to do with a tensioner issue. Mark supplied me with an "aftermarket" belt to use on his engine. It was tensioned to 5.0 and still skipped, when the engine backfired! Your thing would do the same thing, with an aftermarket belt, if the engine backfired hard enough.
Start over and read the first post in this thread! The guy can't figure out how to set the cam timing with the Porkensioner. That's not me talking...that's someone else.
If the piston moves in and out, when you turn the engine by hand...the cam timing is moving, too! Even you can "see" this! How do you control this???? That is the entire question in this tread! He can't set the cam timing with the engine running, or when it is turned over with the starter!!!!
You seriously want to drag Mark Anderson's good name through the mud, like you've done with me? Just saying this is an illusion you might not want to try. I'd suggest you go back and delete this, so Mark's customers don't dislike you, too.
Finally. Why didn't you just say this from the very beginning? Sure would have saved a bunch of time! Your tensioner is not meant for the person who runs his engine to redline...like all my customers do!
Only made for the home guy, that wants to "hold his breath" every time he turns the key. Like you do!
That pretty much says it all.....
Old 07-26-2010 | 05:38 PM
  #142
PorKen's Avatar
PorKen
Inventor
Off ignore sooner than I expected!
Old 07-26-2010 | 05:42 PM
  #143
GregBBRD's Avatar
GregBBRD
Former Vendor
And right back on...until you say something really stupid and someone calls me laughing at you.
Old 07-26-2010 | 05:44 PM
  #144
PorKen's Avatar
PorKen
Inventor
If you recall, you brought up his name.
Chickenman.
Old 07-26-2010 | 06:25 PM
  #145
GregBBRD's Avatar
GregBBRD
Former Vendor
Quotes from Porken:
"Hold your breath when you start it. I do, everytime."
"Only made for the home guy, not for shops." ???????????
"Caution: Not made to take to redline."
Now there's the part everyone needs!
Old 07-26-2010 | 07:10 PM
  #146
PorKen's Avatar
PorKen
Inventor
I guess you need those glasses, after all.
Or is it the Tadalafil? You may want to call your doctor!
Old 07-26-2010 | 08:07 PM
  #147
Ed Scherer's Avatar
Ed Scherer
Originally Posted by Bill Ball
The plug has no head and seemed a bit loose to me as well. It threaded in with no resistance and nothing to stop it. That bothered me from the get-go. I think a bolt could work, although the stock shaft appears to be machined flat underneath and we know it seals, so we went with that after the first ones leaked.
Originally Posted by Rob Edwards
I just left the shaft in there as well. Can't recall whether I used any sealer on it, no leaks to my knowledge.
Right. There's no reason not to leave the shaft there.
Originally Posted by SeanR
That is exactly what I have been doing. I cut a few of them off and then decided that there wasn't a need to.
I wish I would have seen advice like that a couple of weeks ago. I did the set screw thing, with RTV. Seemed pretty loose to me, too. Hope to hell it doesn't leak.
Another related thing to point out here: if you don't leave on (or reinstall) that three hole bracket on the WP (the one that supported the outside part of the shaft (pivot bolt/pin/whatever it's called) that supports the idler roller / tension roller assembly, then you'll regret it when you attempt to reinstall your center timing belt cover. The center bolt goes through the timing belt cover, and if that bracket is missing, you'll discover that there's no backing when you attempt to torque down that bolt. It'll distort the cover by a little more than three mm (the thickness of the now-missing bracket) if you decide to torque it down anyway. Luckily, I noticed something bad was happening and went back and reinstalled the bracket (minus the left end that originally attached to the end of the roller assembly; I just left the "roller assembly pin end" hanging in space). I contemplated just putting a thick washer back there, but that seems unwise, as I can see forgetting about it and then during some future maintenance, pulling the cover off and having that washer dropping unnoticed into the crank gear or something; just too risky.
Now I regret not having just gone back and removing the set screw, reinstalling the shaft and bracket, and everything would have been cool.
As long as that set screw doesn't leak, I guess there's no harm done.
Anyway, IMHO, I'd recommend that the PKsn'r instructions be updated to recommend leaving that bracket and shaft intact; it's likely to cause more trouble by leaving it off than leaving it alone.
And... Ken, IMHO, a lot of your posts in this thread don't exactly inspire a lot of confidence in those of us (like me) who aren't real mechanics by any stretch, but just DIYers. It appears to me that you've got a good product with the PKsn'r, but I'd really like to see as much professionalism as possible displayed by the guy who's behind a what's now a super-critical part of my car. Remember that there are (and will be, for years to come) a lot more guys like me reading this thread, trying to decide whether or not to take the PKsn'r plunge. Seems like it would be a great idea to cover all the bases, regardless of where the debating points come from. I hope that doesn't make me a target, too; I'm just trying to make something constructive out of what has become an unnecessarily nasty thread.
Old 07-26-2010 | 08:54 PM
  #148
Bill Ball's Avatar
Bill Ball
Under the Lift
Ed: Ditto on all your comments.
Old 07-26-2010 | 09:08 PM
  #149
PorKen's Avatar
PorKen
Inventor
And... Ken, IMHO, a lot of your posts in this thread don't exactly inspire a lot of confidence in those of us (like me) who aren't real mechanics by any stretch, but just DIYers. It appears to me that you've got a good product with the PKsn'r, but I'd really like to see as much professionalism as possible displayed by the guy who's behind a what's now a super-critical part of my car. Remember that there are a lot more guys like me reading this thread, trying to decide whether or not to take the PKsn'r plunge. Seems like it would be a great idea to cover all the bases, regardless of where the debating points come from. I hope that doesn't make me a target, too; I'm just trying to make something constructive out of what has become an unnecessarily nasty thread.
Text added.
Wherever possible, I have explained the PKsn'r concept as best as I can, but this is a discussion group, not a user manual. I do not have control over the participants, or the quality of information provided by others.
Many posts ago I realized that GB did not care what I said, he would just find a new avenue of attack. Since he continues to post misinformation that I must counter, I may as well have some fun at his expense. Frankly, the faster it drifts into the abyss, the better, IMO.
That said, there have been a few constructive posts in this thread. For myself, I am pleased to have made the conceptual leap from a limited view of belt tension to a more holistic idea of belt management.
I guess I did hit below the belt (tension?), sorry for that.
Old 07-26-2010 | 09:09 PM
  #150
James Bailey's Avatar
James Bailey
Perhaps the one thing that has been PROVEN is that the 928 engine will run with a wide variance in tension may not run 100% but will run. With a none functioning tension warning light it might even seem that everything is O K .
Quick Reply: Cam timing inconsistant with each revolution
