Headlight aiming adjustment spec Q
Supercharged
Can anyone tell me what the spec is for headlight aiming? I had a floppy headlight that I finally fixed and now I need to re-aim the headlights, but am unsure how high/low I should adjust them.
Didn't see anything in the manual, and I seem to recall someone (Bill?) saying how many inches at so many feet, but can;t find it int he archives.
Under the Lift
3" below horizontal center at 25 feet.
This is for H4s, but basically H5 should be aimed with the top of the beam about the same height. It's just ahrder with H5s because the beam is more diffuse.
![](http://www.billsworkshop.com/P928S4/h5toh4/aim.jpg)
checkmate1996 (04-28-2024)
Under the Lift
2.3 to 3 degrees would seem to be quiet low. 3 inches at 25 feet is about .5 degree. Not seen a sticker on any of my cars.
http://www.danielsternlighting.com/tech/aim/aim.html
Hi Bill,
Don't have access to my car right now, but this is a blown up part of a picture I took when I bought my car. A little hard to make out, but it says 1.3 degrees. Looks like the my memory is starting to slip a little
Under the Lift
Ah, I've never noticed one of those. Not on my 89. Perhaps non-US. Anyway, the basic idea is to get the beam slightly below horizontal so it doesn't blind others.
Chronic Tool Dropper
For US-lamped cars, the center of the main beam is centered on the axis of the car and level with the center of the headlights. With that, the dipped beam will be correct. On a flat driveway, back away from the door 20 feet and get out the tape measure. Throw a towel over the aux main beams in the bumper, and put a tape mark on the door at the same height as the center of the lamp itself as measured from that flat surface. Put another tape mark at the same height, and at the same horizontal spacing on the door as there is on the lamps. You get to go after the side-to-side alignment relative to car center; with the aimer, a pair of mirrors are used, but that shouldn't be too tough to get right. Anyway, with US lamps, get the middle of the main-beam blob lined up on the marks and you'll be good. Having a driver in during adjustment helps some, as does a typical fule and luggage bay load.
Supercharged
The head light bucket really just rests on a paddle that's attached to the shaft that goes across the front of the car.
My problem was that the paddle was not rotating far enough forward such that the bucket was a 1/4" away from the stop at the top. This is what gives it the play and the floppiness.
So I drilled and tapped the paddle (in two spots to even things out) and put in an M5 bolt with some blue locktite and pushed the bucket up to the stop. This basically gave me the extra height I needed to hit the upper stop. Now there's no more slop and does not seem to vibrate when driving.
Sorry, no pics.
