928 Forum 1978-1995
Sponsored by: 928 Specialists
Bilsteins/Eibachs, red calipers, drilled rotors on the GTS
Old 05-27-2010 | 10:48 PM
Chuck Z's Avatar
Chuck Z
Originally Posted by Bill Ball
Here's my fronts with the adjuster just like yours is currently. No problem getting the ride height down. WSM shows the adjuster same way as well. Sure those springs are the right ones (length)? BUT, as others seem to have encountered the same problem and it looks like flipping the adjhuster will lower things, worth a try. Your rear height looks OK; front is on the high end - my guess 175. I shoot for 165. What does yours measure after the front is settled?
The springs have a 928 part number from Porsche - I have a pic of it somewhere just can't find it right now.... The reason I put the adjuster on the way I did was b/c of the WSM however, these are Bilsteins so would it necessarily need to be installed the same way as the Porsche adjuster? I didn't measure the height b/c I have 19s on the front and they are a bit taller than the OE 17s. I cannot lower it any further so do you see a problem flipping the adjuster over in order to gain some adjustibility? I'm not happy with the current height and cutting the spring is not an option so I'm going to try it.
Old 05-27-2010 | 10:49 PM
robot808's Avatar
robot808
Originally Posted by Dean_Fuller
It could be worse....this is what happened to me today. Took ALL day to epoxy Primer my son's car under a metal cover and then a rain storm with high winds. Guess who gets to start over?
It looked sooo nice right before it was ruined.
Oh Fudge!
Old 05-27-2010 | 10:50 PM
Chuck Z's Avatar
Chuck Z
Oh man! That really sucks! I've been following your progress on this project. Very ambitious to say the least. I'll be painting my Japanese/Swiss mudflaps..... out of the weather.
Old 05-27-2010 | 10:56 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Well, the early 928 front springs were longer, but that's real early. Also, you won't be the first person to put the adjuster on that way....from Carl's site....but it looks like it would be hard to get a wrench on the adjuster.
Old 05-27-2010 | 11:00 PM
robot808's Avatar
robot808
Bill, you talkin' 70's early?
Old 05-27-2010 | 11:01 PM
Chuck Z's Avatar
Chuck Z
THAT is the one thing I'm worried about....... Wonder if the long collar on the adjuster could be cut down ~1/2" or, if there is some sort of spacer to give you more room to get the spanner on the adjuster?
Old 05-27-2010 | 11:21 PM
Chuck Z's Avatar
Chuck Z
BTW Bill, Carl shows that as the only pic with the adjuster and shock together and doesn't say NOT to install this way..... One has to think it is not incorrect to install the adjuster oriented in this manner?
Old 05-27-2010 | 11:24 PM
rluvsporsche's Avatar
rluvsporsche
Welcome Chuck. You still have your E55 Estate? Awesome car..
Old 05-27-2010 | 11:32 PM
Chuck Z's Avatar
Chuck Z
Nope. Sold it to a couple in Atlanta a couple months ago. It was an awesome car though.... Just picked this up last night as it's replacement:
Old 05-27-2010 | 11:46 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Chuck from the pictures you have the collars on the correct way, see how the bevel fits the lower perch the fat end isnt made to fit the perch
Old 05-27-2010 | 11:49 PM
AO's Avatar
AO
Supercharged
You're such a car ****, Chuck.
That's a compliment.
Old 05-27-2010 | 11:52 PM
Glenn M's Avatar
Glenn M
Chuck,
God luck with the springs, love the Panamera color!
Old 05-27-2010 | 11:56 PM
rluvsporsche
That's beautiful, dont see too many of those around here. I have to get me one of those once the price comes down (used)
Old 05-28-2010 | 12:04 AM
Chuck Z's Avatar
Chuck Z
As long as the other side makes contact all around equally would that really matter? I did however notice the same thing. When I take mine apart tomorrow I'll see if the look the same.
Old 05-28-2010 | 12:06 AM
Chuck Z's Avatar
Chuck Z
Thanks guys on the comments regarding the Panny. It's quite a car although suspension woes on the GTS have prevented me from being able to bond with it......
I admit it!! It really is a sickness with us although I've gotten to experience a pretty wide variety of cars over the years.....
Quick Reply: Bilsteins/Eibachs, red calipers, drilled rotors on the GTS
