Twin Turbo 928 fixed and back out there terrorizing the streets!
#436
The factory steel clamp expands less than the MAF housing with temperature. With factory clamps, one has two choices. Either leave the clamp a bit loose, which means that it will leak or blow off. Or tighten it really tight, which means that the clamp will cut into the rubber boot every heat cycle. These constant torque clamps deal with this heat expansion problem.
With a groove, I hope the whole package will live happily ever after.
#437
The factory clamp width would be fine, but with more boost the factory clamps *cause* the MAF boot to break.
#440
Quiet exhaust
I've been slowly working on a really quiet turbo exhaust. It's one of those two out of three deals: Out of quiet, high-flowing, and light you can have any two. I am trying to go for quiet and high flowing but compromising on weight.
There's a custom muffler oval midpipe, a couple of 3" magnaflows, and a 4" magnaflow. All laid out on the floor:
Next, it's time to order the pieces to fill up the gaps.
#441
I have looked through this thread, and must be missing it, or it isn't here. But I would love to see pictures of how the system is laid out.
I can't come up with the words to describe what your project does to me. It's a combination of being in the middle of changing engine mounts in my 89 GT, and from having built up a turbo system in 1979.
So I guess that translates to nostalgia combined with the fact that they put cars together now so that one can't even fit their hands into the empty spaces between parts.
I really want to see how this all fits in. Please, please post some photos.
#442
I too am really really intrigued with the look, and function, of this build.
One thing I would really be sad to see is that if the Y pipe dose not allow full access to the be lower bell housing bolts. When I had the muffler shop build mine, that was a must so that I could slide under and check the drive shaft preload without having to drop the exhaust.
It is a must.
But I really like what you have done so far. More pics please
It is a must.
#443
Sorry Brad,
But if that exhaust is on your car you should take it off and throw it away.
From that 1 picture I can tell you that it is going to hurt performance, and caused decreased life of the O2 sensor.
#445
The parallel Y of this mid pipe is then connected to the cats with V-band clamps.
The splayed Y of the mid pipe will go to where the stock resonator boxes usually are. I'll have two oval mufflers there, one on each side.
After the mufflers, I will merge the 3" pipes back into a single 4" pipe and hook them up to the 4" rear muffler.
I don't really know what it is.
I bought a nice garage in the spring and it came with a house attached to it. The house has a number of rooms and one of them has a floor like that. It's probably some sort of soft wood.
The rug is an old rug, back from the days when I was a college professor and only could afford to shop furniture at IKEA.
#446
Your exhaust system is gorgeous, right on down to the clamps, but my curiosity lies in what is happening at the exhaust manifold end of things. I suppose that's pretty tough to get a picture of.
Overall this is just a very well thought out and implemented project.
#447
Here's the exhaust manifolding of John's kit:
#448
Tuomo let me drive this car at Tass's GTG last month. Thanks Tuomo!
This thing is holy $hit fast, and I have to admit I was scared to get near peak power. The only other thing I can compare it to is a 996TT X50 I drove, and this is quite a bit faster. My .02c
p.s. I have driven a murph '89 5 speed making 470 at the wheels, and a DR '90 GT making 400+ at the wheels, and they were both strong but this 928tt is sort of in another ball park.
I would say that the DR "90 GT was the most drivable and usable (of them) in my opinion.
