928 Forum 1978-1995
Sponsored by: 928 Specialists
Delrin Rack Bushings-What a difference!
Old Jan 21, 2010 | 11:37 PM
  #31
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Oh man I want those....this list is getting really long
Old Jan 21, 2010 | 11:40 PM
  #32
Ducman82's Avatar
Ducman82
Veteran: Air Force
i hope to have mine in the mail tomorrow. pics would rock!
Old Jan 22, 2010 | 08:48 PM
  #33
Ducman82's Avatar
Ducman82
Veteran: Air Force
so, i have have taken the brace plate off, but the old bushing WILL NOT COME OUT.... im thinking i will have to take the rack OUT to press them out.... not to mention the 17mm bolt need to be held on the top end and on the drivers side are almost impossible to hold... ugh. any tips or tricks to this?
Old Jan 22, 2010 | 08:57 PM
  #34
Stromius's Avatar
Stromius
Air hammer with a notched chisel bit is the only way to get the old ones off in a timely manner.
Old Jan 22, 2010 | 09:07 PM
  #35
Ducman82's Avatar
Ducman82
Veteran: Air Force
with it hanging or out of the car?
Old Jan 22, 2010 | 09:09 PM
  #36
Giovanni's Avatar
Giovanni
How about being creative with a C-clamp with the rack hanging?
Old Jan 22, 2010 | 09:16 PM
  #37
Ducman82's Avatar
Ducman82
Veteran: Air Force
working on that as we speak (C-clamp idea)
Old Jan 22, 2010 | 10:42 PM
  #38
Ducman82's Avatar
Ducman82
Veteran: Air Force
well i dropped the rack... sort of. i might even replace it since im there, but it WILL NOT separate from the steering coupling on the steering wheel shaft. what i need is the jaws of life. but when i do get it out, i cant wait to install the bushing! they look great!
Old Jan 22, 2010 | 11:06 PM
  #39
Stromius's Avatar
Stromius
Hanging worked for me. Air chisel (sorry meant that not hammer) worked the old ones out.
Old Jan 22, 2010 | 11:08 PM
  #40
Giovanni's Avatar
Giovanni
And you can pick on from HB for less than $3; http://search.harborfreight.com/cpis...ord=air+chisel
Old Jan 22, 2010 | 11:10 PM
  #41
Ducman82's Avatar
Ducman82
Veteran: Air Force
ya im going to get one tomorrow. i got the rack off. stubborn bugger. not to clean and press out the old bushings..
Old Jan 23, 2010 | 01:20 AM
  #42
Ducman82's Avatar
Ducman82
Veteran: Air Force
so after getting the rack out, i found this rubber with a metal ring around the out side of the bushing.
but after beating it out, the new bushings fit right in!
Tomorrow when i get the rack back in the car, ill take another after picture!
GREAT product 928RUS!
Old Jan 23, 2010 | 03:35 PM
  #43
Ducman82's Avatar
Ducman82
Veteran: Air Force
Here is the installed picture!
Old Jan 23, 2010 | 05:34 PM
  #44
G Man's Avatar
G Man
Cool. Thanks for sharing the pics. Does this process mess with the alignment? Give an update after the test drive please.
Old Jan 23, 2010 | 05:45 PM
  #45
Ducman82's Avatar
Ducman82
Veteran: Air Force
as long as you dont mess with the tie rods ends, you should be ok. im guessing later cars had different bushing that are not "formed" on the rack the this set was. i had to take the rack out to get them off. the hardest part of doing that was getting the splines for the steering rack and the coupler to go back on.
