928 Forum 1978-1995
Sponsored by: 928 Specialists
Did I lose them, or: I never had them?
Old 01-09-2010, 09:39 PM
BC
BC's Avatar
Default Did I lose them, or: I never had them?
The rear head seals where the cam journals are - they are rubber pieces with shafts that stick out radially.
Does a standard seal kit for a 32V engine come with these? Or does it not?
I thought I had them. I may have. But I am no longer sure since the seal kit was purchased in 2003.
Old 01-09-2010, 10:11 PM
Shark_Week
Shark_Week's Avatar
just curious, how long will a seal kit be good for? i'm assuming they have a shelf life. the o-rings we use usually have a cure date and will expire
Old 01-09-2010, 10:30 PM
BC
BC's Avatar
Sitting in a box? Probably a very long time.
Old 01-09-2010, 10:34 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,489 Likes on 1,401 Posts
I dont recall ever seeing these block off plugs in a engine seal kit.
That said there are updated parts that are just rods about 27 mm long that have an end turned down to fit into the oil feed hole the cam cap holds the other end in place. If you have the old style round rubber with pin then these should be swapped out to the new pin design
Old 01-09-2010, 10:40 PM
Hilton
Hilton's Avatar
Yep, the part you're talking about was superceded by 928 105 262 00 - there's a technical bulletin about it somewhere.
The original-style rubber bit with the radial spike can warp and fall out of place, causing a drop in oil pressure as the journal is uncovered.
Old 01-09-2010, 10:54 PM
BC
BC's Avatar
Well there it is. Thanks guys. I did remember the thread about the shafts, but I thought THAT was the superceded part - the rubber stuff. So no more rubber plug - just the shaft itself.
Interesting. Well - I think now I know I don't have either.
Old 01-10-2010, 01:11 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Are these the black steel/rubber caps for the cam journals?
Old 01-10-2010, 01:15 AM
Jim Morton
Jim Morton's Avatar
FWIW, they do not come with the commonly distributer "full" gasket set.
The rubber versions with the protruding pin are NLA, but the later style that's a shouldered pin is still available.
Good luck trying to find yours if they are buried...
Old 01-10-2010, 02:09 AM
BC
BC's Avatar
Everything was buried. But we movied, so everything was basically excavated and repackaged for the move (see my thread mentioning the carts I got for each engine). So most of my stuff was re-organized. I had a few casualties.
But I did have the entire seal set - I just thought maybe I misplaced it much earlier.
Old 01-10-2010, 02:10 AM
BC
BC's Avatar
Yep. Seems like they were superceded by just these little shafts.
Old 01-10-2010, 10:56 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I see, My '85 must have had these replaced before I bought it as they were already the new parts. Also, the gasket set I got when I bought the car, with the broken t-belt, did include a new cap set too but I got this off ebay. It was made by Victor Reinz but I don't know if the seller put it together or if it was a manufactured kit.
Old 01-10-2010, 12:00 PM
ROG100
Basic Sponsor
ROG100's Avatar
$1.20 each and you need 5.
Plenty in stock
Old 01-10-2010, 02:44 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Plenty in stock
5 ??? I thought there were 6 caps and 2 seals for the cam gears.
Old 01-10-2010, 02:52 PM
Jim Morton
Jim Morton's Avatar
One of the four journals requires two pins... passenger side exhaust cam.
Old 01-10-2010, 03:00 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
You guys do realize that you are talking about two completely different kinds of cam seals, right?
Some of you appear to be talking about sealing the external cam bore holes in the front and back of the cylinder heads, and some appear to be talking about the pins that plug the unused oil holes in the cam bearing saddles...
Quick Reply: Did I lose them, or: I never had them?
