928 Forum 1978-1995
Sponsored by: 928 Specialists
Porken's 85 chips- Awesome!
Old 04-20-2012, 09:51 AM
  #601
SMTCapeCod
SMTCapeCod's Avatar
Wink By the way
not to interrupt, but
Old 04-20-2012, 09:56 AM
  #602
rad_951
rad_951's Avatar
Pyzik,
It sounds like your car was running normal, then you installed the chip (and nothing else) and the idle changed. Could it be that the vacuum line to the computer was disturbed?
Anthony
Old 04-20-2012, 10:03 AM
  #603
Mike Frye
Craic Head
Mike Frye's Avatar
heh heh. I need that image. Thx.
Old 04-20-2012, 10:24 AM
  #604
Pyzik
Pyzik's Avatar
[QUOTE=rad_951;9461824]Pyzik,
No I always check that, but when I picked up from shop, they Forgot to plug it in!
Old 04-21-2012, 04:33 PM
  #605
Pyzik
Pyzik's Avatar
Alright guys , my maf is at 382ohm my cold fuel pressure is 58psi, car runs great till it reaches 4000rpm then it stops pulling But the idle still slowly rises and then after slowly getting to 5000rpm and after that doesn't really pull . Would that be the fine adjstment of Co and the idle screw ?
Old 04-22-2012, 01:20 PM
  #606
PorKen
Inventor
PorKen's Avatar
Check that the WOT switch is working at the LH plug (12 & 25).
New ICV.
If MAF has not been rebuilt, it needs to be.
Old 04-22-2012, 05:01 PM
  #607
PorKen
Inventor
PorKen's Avatar
Note that the MAF has two o-rings. A big one in the housing, and a small one on the MAF. Both screens should be installed.
Make sure the MAF is right side up! I've seen a couple that were installed upside down!
Arrow on cover should be pointing away from the air filter/towards the throttle body.
Durchfluß
Flow
Old 04-22-2012, 06:46 PM
  #608
Pyzik
Pyzik's Avatar
New ICV.
Does the icv affect performance or just the idle? Also what's the best way to rebuild the maf?
Old 05-11-2012, 12:54 AM
  #609
Pyzik
Pyzik's Avatar
This is what happens , it starts and dies
http://www.youtube.com/watch?v=h2bc3uFfDzk
Old 05-11-2012, 03:12 AM
  #610
Avar928
Avar928's Avatar
Have your MAF sent to Injection Labs (http://www.injectionlabs.com/) and Kevin will rebuild it, with a warranty included. He's in Boulder, CO so just email him that you're sending and write down all your info and send it with the MAF.
I sent mine in, turnover time was about 5 days from when he received it (USPS Flat Rate). Cost about $265 plus shipping.
My '86 is so much more responsive now.
+ Edit
I believe the Idle Control Valve just affects idle and won't factor into overall performance. I could be wrong though.
Old 05-11-2012, 03:32 AM
  #611
danglerb
danglerb's Avatar
ICV not working, sticking, can cause a car to die right after starting, or idle high and somebody adjusts the idle screw instead of replacing the ICV and makes it worse when it unsticks.
Old 05-11-2012, 08:31 AM
  #612
Mike Frye
Craic Head
Mike Frye's Avatar
Good call!
One of the major causes of confusion and complications when diagnosing a problem: What could have been done to deal with this in the past, and what effect would that have had?
People start adjusting things to deal with the symptoms without fixing the original underlying problem. Then when they finally find the original problem it still doesn't run right. At that point it's time to go back to the start and get everything back where it was.
Old 05-11-2012, 09:43 PM
  #613
Pyzik
Pyzik's Avatar
Just I be clear , you guys are saying that that might be coused by a bad icv?
Old 05-15-2012, 10:01 AM
  #614
Pyzik
Pyzik's Avatar
Last night I disconnected the maf and the car started right up and ran no problem, I'm sending my maf in, thanks for all the help everyone!
Old 06-22-2012, 09:35 PM
  #615
Pyzik
Pyzik's Avatar
Hello again, I got the maf rebuild, new icv, new intake plenum clamps all around , car runs really good , starts right up , idles great, sounds healthy, but something is still going on , when the car gets to 4k rpm it starts pulling really nice but kind of slow to get to 4 rpm. Any ideas what it could mean? Same thing was going on when I bought the car with eBay hips in it. Also I read in s300 description that the chip Is supposed to run little higher rpm t start up for couple sec to warm it up quicker, and mine just. Starts an right away rpm is at 700. Would it be the aluminum fly wheel? Sorry. I keep Bothering you guys but I want the car to run its best and you guys are the 928 know it all pros!!!! Im. Feel lucky to get all this help from you guys! Thanks again.
Quick Reply: Porken's 85 chips- Awesome!
