Black Widow track shark for sale!!!!!
If you can talk mama into a little $$$ I can make you a smokin deal on my 78' "Track car".
Gerry
Gerry
Former Sponsor
After too many arguements with my wife over racing expenses and increasing the racing fleet to include a lemons racer.....something has to go.....and its the Widow.....
Heres some details (the good)
89S4 5speed with LSD
Full 6 point cage of 1.75 x.120 DOM with triple nascar bars drivers side
Koni shocks with Eibach straight rate springs 800F 300R
Carls adjustable drop links with tow hooks
1 Racetech 4009 WHR (wide hans-headrest seat) (these are $1300 new)
short shifter, carls all metal forward shift bushing and improved center bushing, with new rear bushings
GTS front brakes, S4 rear with braided steel lines and Pagid Orange pads, lots of life left
Custom welded in GTS rear flares with fender rolling...77" wide at rear tires
Custom CCW C10 black anodized wheels 18x10x9" backspacing front.. 295/30-18 Toyo R888's in excellent condition (over 50%) rears are C10's black anodized 18x12x8.25 backspacing with Toyo R888 335/30-18's with over 50% life left....an extra set of 335/30-18 Toyo R888's with about 50% life left are also included.
Heavy duty clutch pressure plate with brand new clutch disc and slave cylinder
33bar brake bias bar with 600 degree Motul brake fluid
3 qt Hi pressure accusump with 55-60psi EPC valve
Greg Brown 3/8th " pan spacer with windage trays
Taylor drilled 5.0L crankshaft
19 row setrab oil cooler mounted behind drivers side foglight
all aluminum 928intl race radiator
fans custom wired to a relay to trigger at 180F
steering rack-tire rods replaced by prior owner about 500 miles ago, power steering pump is a new rebuilt unit
upper A arms replaced by prior owner
waterpump-timing belt are around 500 miles
928intl headers into custom 2.5" mandrel bent stainless steel exhaust
red crinkle coat valve covers and intake with Carls intake spacers
improved breather on both valve covers vented to catch can.
928intl improved crankcase filler neck baffle
Sharktuner II with two full sets of PEMS and both adaptors to tune either 89+ or 87-88
Without sharktuning it consistently ran around 300whp with a stock 5.0 engine-cams
2875lbs approximately
The bad :>(The engine had a 4-8 rod bearing failure for a yet undetermined reason.
I have owned this 928 for approximately 1 year... I paid $13,500 and have nearly $40k invested in this project, and DO NOT want to sell...but for the sake of martial bliss I have no choice.... something has to give and divorces are pricey
The car is located in West Sacramento CA and will need to be towed, as it is not running nor street legal.
Open to all offers and will part out, if no buyer for the full car.... looking for $15k..... I plan on using the funds EXCLUSIVELY to fund my track and Lemons racing habit.....since it appears I can't afford a "real" race car according to my wife...
Heres some pics
Heres some pics
That usually makes them think, if they don' kill you the second it comes out of your mouth.
What you need to do is to put a really high price on it and let it sit for a year. Then you can bring up the argument that it is not getting sold since it is broken and need to get fixed.
Once it is fixed you'll need to book track time to give potential buyers opportunity to test drive it.
Former Sponsor
Hey Brian-
Sorry to hear about the Widow. I was looking forward to getting some track time in with you next summer.
Do you have solid idea of what it's going to cost to rehab the motor, if a complete rebuild is called for?
By the way, never quote costs in front of a wife. Around here, we speak in terms of RCUs (Race Car Units). You can assign any value you want to them, but we figure them at $100 each. So if your wife hears you say that something is going to be about 65 RCUs, (65 units, for short), she won't know you just spent her trip to Europe.
Man of many SIGs
Man of many SIGs
Freedom
(Charley has multiple Sharks and no wife)
Society won't let a man have multiple wives ...so I think it only fair to have multiple Sharks and no wife...I am working on my third P car and no wife...I see it as only a truly free man can...
Hey Brian-
No worries I WILL be at the track more with the widow "gone".....less money to the widow means more seat time for me!!! it will just be in the lemons "budget" racer.....I figure I will buy a set of R comps to use for trackdays....otherwise it will be the same car!
I wanted this car last time around...Im sure I'll get the same answer this time also!
Im about to drop 10k on interior shutters for the dang house!
So are we talking new block? new rod bearings?
Seeing as your selling Im assuming the more expensive of the two?
I lost rack of the "history" but is this failure from a recent rebuild you did? or the one on it when yo ubought it?
Awesome looking car! really is!
