New Product - Illuminated Center Console Switches
#31
Electron Wrangler
On the <'90 cars you can connect the illumination directtly to the switch power connectons: Brown & Red wires on the window switches.
I don't really see any need to dim these (e.g. the mirror mem switch illumination does not dim), In this config they will be on whenever the car ignition is on - and until you open a door (all the time the windows are active - seems appropriate).
This does not work the same on the later cars...
Alan
Alan
#36
#38
Received 1,621 Likes
#39
Just a quick update. I will try to post some instructions this weekend. The creator/maker of the switches is sick at home right now and needs a little rest. He thinks he will be good to go this weekend again...
#42
There are variations to suit all years and tastes, with or without wiper.
With V8 without V8.
I just brought in an intial 10 sets and had to decide at that point what variation.
Remove and replace the switch cover and run some small diamter wiring back to a source, permantent or switched. Comes complete with the light source and wiring.
Will be fitting a set to my GTS asap.
With V8 without V8.
So each switch needs a separate power source to illuminate it?
#43
For those who want to blank off two locations, a square plate came on non-sunroof 78(and probably others that had the wiper switch in the pod) that takes up two switch positions with one part:
![](http://members.rennlist.com/sharkskin/Pages_SA_R30-Drivetrain-ConsoleAssembled.jpg)
#45
