928 Forum 1978-1995
Sponsored by: 928 Specialists
Identifying a LSD without disassembly?
Old Apr 24, 2009 | 06:53 PM
86'928S MeteorGrey's Avatar
86'928S MeteorGrey
Default Identifying a LSD without disassembly?
I was told my 86.5 has a LSD... I have not torn into the rear end yet. The car does not have its options list in the trunk. I've been meaning to ask this for some time, but it always seems to SLIP my mind...
Questions...
Is there a way to identify a LSD without visual inspection? Can a LSD be identified with both rear wheels off the ground? Can a LSD be identified by the handling characteristics of the car?
Old Apr 24, 2009 | 07:09 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Turn the rear wheel. If the opposite wheel turns in the same direction, you have LSD. If it turns in the oposite direction, its not LSD.
Old Apr 24, 2009 | 07:30 PM
PorKen's Avatar
PorKen
Inventor
This is what greeted me the first time I had my '86.5 on the lift.
Old Apr 24, 2009 | 07:33 PM
mark kibort's Avatar
mark kibort
ONLY if it is in neutral.
mk
Old Apr 24, 2009 | 07:50 PM
86'928S MeteorGrey
Cool news. Thanks! Since I have the front jacked up pulling the engine, It probably won't be until next week before I can check by rotating the wheels...maybe I can see the transmission... Sperrdiff means LSD?
Old Apr 24, 2009 | 08:15 PM
Sailmed's Avatar
Sailmed
From: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
Questions...
If it was a 5 spd you could do a burnout and look behind to see.
Flame suit on
Old Apr 24, 2009 | 08:19 PM
Hilton's Avatar
Hilton
If the transaxle hasn't been opened and midified internally since it left the factory, you can also tell from the serial number of the transmission. Its found on the bottom edge at the rear, facing the ground.
LSD has a 2 instead of a 1 in about the 5th digit (from memory - I'll go check in a min)
Edit: nevermind - seems that was a change only introduced in the S4-onwards years
Old Apr 24, 2009 | 08:52 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
mk
What does it do in drive or reverse?
(This is hardly a trick question... )
Old Apr 24, 2009 | 09:09 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
If it's a 5 speed, it gives you a hernia.
