My new OB / Racer in the making
#46
Adam,
Ihave a set of 1980 Euro S spindles, rotors, and calipers w SS brake lines and I think the pads in the calipers are Hawke HPS with maybe 5k miles on them. t
The alipers are 282 mm dia and 32 mm thick, slotted Zimmermanns. They were left over from when I upgraded to the S$ setup on the front. You can have them for the cost of shipping fron VT. PM me if you are interested
Paul Mammorella 1980 Euro S Red/Blk lea
#47
The Parts Whisperer
Adam,
#48
yep, and scot is racing on them still. When the times get down, you start cooking them pretty good, but the rotors are pretty cheap and pad make a huge difference. Pagid oranges work well, if you replace them at 4mm. Scot hasnt tried pagid blacks yet, but that will probably be next. (or some equal race pad). I raced once with the old OB brakes. they were downright scary. Did a 2:10 at thunderhill on them with 200rwhp, 3100lbs with my O.B . Fun, but 'S' brakes would have made it less nerve-racking!
mk
mk
Glad you had a good time with your OB but I must say I'm in total agreement with the brakes. Having worked on a few OB's lately I was reminded how bad they really are.
Try to get your hands on a 82-86 brake set up. It is a huge improvement and affordable. Kibort raced with them for years and when he went to the S4 brakes he said they were not much of an improvement . If you can't find them locally I can provide everything for $250 plus shipping.
#49
I had people come up to me in the pits and say they could smell my brakes two turns back
Thanks for the awesome offer Mark, Tom M. has a set from his '82 since he's upgraded to S4's.
If I find a killer deal on some 17's, I may skip right up to the big reds with the adapters, but we'll see. No rush, I won't be seeing another track day for awhile.
#50
Adam,
Let me see what I've got to work with here, and I'll get back to you either way.
Very generous!
-Adam
#51
The budget build continues....
Thanks to Chuck Ahrens for offering up this slightly abused set 993 Twists for $300. Ed Boyd offered doing a labor trade (motor mounts and pan gasket) in exchange for the Toyo RA-1's he had for sale. Heck yeah! These are 245/45x 18 and 275/40 x18's.
Here she is shod with the track wheels. Not bad, got to get some adjustable front perches so I can lower the car to race ride height.
Here's the OB with a couple of 928 friends. My S4 (which has been seriously neglected since the Ott Flare Install - finally washed all the dust off her today) and Mark Jacobson new S4. Very nice.
OB track car tally so far:
Car $ 500
GT2 wing $ 100
Track Rims $ 300
Tires $ 0
Colin Jensan Short Shifter $ 100
(Proto-type)
Total $1000
Good Buddy donations:
Steel ball joints - John Davis
Brake Calipers - Tom Middleton / Ken Osage
Interior Door mechanism - John Davis
Track Seat - Tom Middleton / Ken Osage
Stock seatl belt - Tom Middleton
Radiator - Tom Middleton
Battery Positive lead - Ken Osage
Trouble shooting electrical so all lights work - Ken Osage
Next on the list - S4 front brakes.
I'm definitely not worthy of all the time and parts these guys have helped put into this track car. I'm hoping to be able to return the favors some time soon.
I very much look forward to the day in the not too distant future where we all get to grid in our race prepped 928s.
Car $ 500
GT2 wing $ 100
Track Rims $ 300
Tires $ 0
(Proto-type)
Total $1000
#53
Haven't had a chance to put the bushings in the back yet Colin. When I had the car on the lift putting on the track rims, John Davis mentioned that my car was the only one he's seen that still has the rubber boot covering the rear coupler, so I guess that's a good sign.
Yeah rims / tires definitely are staying in the budget theme of this build. Ultimately, I'm hoping to find another pair of ragged out 10" twists to run in the front. Hoping to do the split fender mod to make them fit.
#55
Definitely Brian. After brakes just need a little more motivation under the hood. Looking to drop in the 5L out my S4 when the stroker goes into it.
#58
Well, these won't win any beauty contests (yet), but they are S4 front calipers, and they were only $200. Thanks John Davis!
And to sweeten things up a bit, John tossed in a set of S4 rotors. Now these had a pretty major ridge on the outter rim of all eight surfaces and were kind of rippled on the contact surfaces. In all honesty I didn't think that they were going to be usable, but I thought I'd take them to the local machine shop to see if they could be turned. $15.95 each later, this is where I'm at. Awesome! Those of you who like me think that your only option with worn rotors is to replace at $100+ a pop, here's your $65 answer.
#59
Running Tally:
OB track car tally so far: May 20th, 2010
Car $ 500
GT2 wing $ 100
Track Rims $ 300
Tires $ Trade
S4 front brake adapter $195
S4 rear calipers $ 75
S4 front calipers $200
Turn brake rotors $ 63.80
New 993 Front Rotors $ 208.50
Stainless brake lines $ Trade
Caliper bolts $TBD
Aftermarket springs $106.19
Sparco Race Seat $250
CV Boot Kits (4) $ 60
WP Shoulder Bolt
Alignment $ 84
Plexi rear glass $137
Sparco Sliders $ 70
Sparco Side Mounts $ 79
Sparco Hub Adapter $ 75
Edis 8 Ignition (Used) $ 75
GM Injection Harness $ 20
Used Mini Start $100
Pan Spacer $235
Used Pan Insert $ 40
First DIYA Shipment $ 365.50
-GM CLT & air sensor
-Innovate MTX-L
-12' wiring harness
-36-1 trigger wheel
Ford Contour Rad Fan $ 38.10
Total: $ 3,111.59
Steering wheel - Ken Osage
Center console/fan switch/fuel pump switch - Ken Osage
Battery Kill switch - Ken Osage
Used rear S4 rotors - John Davis
Adapter and Caliper Bolts - Ken Osage
4.7 Long Block - John Davis
Car $ 500
GT2 wing $ 100
Track Rims $ 300
Tires $ Trade
Caliper bolts $TBD
WP Shoulder Bolt
Alignment $ 84
Sparco Sliders $ 70
Pan Spacer $235
-Innovate MTX-L
-12' wiring harness
-36-1 trigger wheel
Total: $ 3,111.59
